Question about Apple iPod nano
Ipod Nano Showing Error Icon
I've lost my usb cable ,which is my charger too .And I bought a new duplicate charger after 3 months
When I'm using my Ipod after 3 months it shows afolder icon with "!" this symbol and shows alink www.apple.com/support/ipod
This shows anytime I press the ipod
Posted by Mr_K_K on
Anonymous
  • 35 Answers
Http://docs.info.apple.com/article.html?artnum=61003
You can check out that website. It has ideas and suggestions on how to fix it.
It might be that your ipod needs to be charged. Or maybe reset. But follow that link and it should show you how to fix it.
Posted on Nov 08, 2007
I have an ipod model a1199. i was wondering if you can use a newer ipod touch charger for it? and if not what kind of charger does it use?
Charge an iPod Nano Without a Charger
If you've misplaced or broken the charger that came with your iPod Nano, you might think you need to purchase a new one in order to continue using your Mp3 player.
However, there is a way that you can continue enjoying your iPod without having to purchase a new charger.
As long as you have a USB cord and a computer, you can charge your iPod without having the charger.
Locate the USB cord that came with your iPod Nano package.
It is the same cord that you use in order to sync or transfer music.
Plug the small end into your iPod Nano.
Plug the other, larger end into your computer's USB port.
Choose "Do Nothing" when your computer presents the dialogue box to let you choose what to do with the hardware or USB connection.
Leave your Nano plugged into your computer for at least 4 hours to charge.
Unplug your iPod Nano when charging is complete.
Charge an iPod Without the Charger
Many iPod owners purchase a charging unit that plugs into a standard wall outlet to recharge the iPod's battery.
However, the iPod wall charger is not included with new purchases, so consumers must either purchase a separate charger or find a way to charge their iPod using other means.
Here's a simple method to charge your iPod using your computer.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by clicking on the icon in the Dock on a Mac or using the Start menu on a PC.
Click on the name of your iPod under the "Devices" heading in the main iTunes window.
Click on the "Sync" button to synchronize your iPod with your computer data.
While the iPod is syncing, the power from the USB port on your computer will charge your iPod's battery.
Unplug your iPod from the computer once the battery is fully charged.
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=8DEA58C0DAF392E29FCB03D9C
This one should be ok.
Aug 05, 2013 | Apple A1199 ipod nano
Tip
How to convert a USB Battery Charge Cable to AC
<p>Many of the new battery-operated devices such as phones and MP3 players come with USB cables to charge the battery while the computer. However, wall chargers for these items are missing, damaged or undelivered. If so, you can use a USB wall charger, USB cables, adapters and because all have the same size at the end with these boots are endless. <br /> <p><br /> <p>Generic Battery <br /> <p>1. Buy a USB wall charger. These are available online through www.amazon.com and www.bixnet.com or a limited number of electronics stores like Radio Shack or Best Buy. <br /> <p><br /> <p>2. Connect the USB end of cable to the USB wall charger. <br /> <p><br /> <p>3. Connect the charger to the USB cable. Then connect it to the wall. The machine starts working the green light. <br /> <p><br /> <p>iPod Battery <br /> <p>1. Connect the USB cable to the iPod. Be sure to press the two ends before inserting it into the iPod. If you do not, you can damage the pins, once that happens, you will not be able to charge your iPod. <br /> <p><br /> <p>2. Mount the USB wall charger sliding the top in half, for the manual. <br /> <p><br /> <p>3. Connect the USB cable for both USB wall charger. Plug the wall charger. The costs start when the lights come back on the iPod screen and you will see the battery icon fill. You can find this anywhere iPod charger are supplied. <br />
on Aug 09, 2011 | Apple iPod touch
I have a 8g ipod nano model number a1199 and i got it awhile back and i lost it. recently i found it and forgot the password. is there anyway i could reset the whole ipod... or whatelce could i do?
The latest iPod Nano includes a locking feature, which allow users to set a four-digit combination to keep intruders from using the device. However, if you find that you forget what code you set on your iPod, you will need an alternate way of unlocking your iPod Nano. Once the device has been successfully unlocked, you can continue listening to music on it.
Plug the iPod USB cable into the bottom of the iPod Nano. Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC. Click on the name of your iPod Nano under the "Devices" list in the iTunes window. Click on the "Sync" button to establish a connection between your iPod and the computer. Click on the eject symbol next to your iPod's name after the syncing process has finished. Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again. Hope it helps.
Jan 23, 2013 | Apple A1199 ipod nano
DESBLOQUEAR PANTALLA
How to Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod. In order to use the device's functions again, you need to enter the correct code. However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Things You'll Need:
iPod Nano Mac or PC computer iPod USB cable
1 Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
2 Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
3 Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
4 Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
Jan 05, 2012 | Apple iPod nano
Enter code i pod \
Hi
Things You'll Need
Dec 30, 2011 | Apple iPod nano
I have it on lock and i bought it from a pawn shop. I don't know my code and how do I unlock it!?!?!?!?!?!?
Plug the iPod usb cable into the bottom of the iPod Nano. 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or pc computer. 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC. 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window. 5 Click on the "Sync" button to establish a connection between your iPod and the computer. 6 Click on the eject symbol next to your iPod's name after the syncing process has finished. 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features
hope this helps and please vote
Dec 02, 2010 | Apple iPod nano
I got a new 5th gen ipod nano not reconised by itunes
I found this article on apples web site I thought it might be helpful
http://support.apple.com/kb/TS3218
Apr 14, 2010 | Apple iPod nano 5th Generation
I have an ipod nano 3rd generation and it won't unlock
1. Plug the ipod USB cable into the bottom of the iPod Nano.
2. Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer.
3. Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC.
4. Click on the name of your iPod Nano under the "Devices" list in the iTunes window.
5. Click on the "Sync" button to establish a connection between your iPod and the computer.
6. Click on the eject symbol next to your iPod's name after the syncing process has finished.
7. Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again.
Sep 24, 2009 | Apple iPod nano 3rd Generation
Mains charger
i contacted apple support and emailed them with the problem and as it is still under warranty, they are going to send me a packaging box to send back to them so they can see what the problem is. if they can't repair it they will give me a replacement ipod. i have only had it 6 months and it has been working fine, but lately i cannot charge it by mains or car charger, only usb cable.
Jun 01, 2008 | Apple iPod nano 3rd Generation
White ipod nano will not stop showing "do not disconnect" icon....
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more asistance, let me know. Good luck.
Mar 23, 2008 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
