Question about Sony Handycam CCD-TRV37 Camcorder
8 mm tape will not eject or release from ge camcorder
Won't release the cassette
5 Related Answers
Anonymous
  • 196 Answers
SOURCE: PLEASE HELP!! Sony Handycam CCD-TRV37
The problem is usually caused by no drum rotation. Have it serviced.
Posted on Feb 13, 2006
Anonymous
  • 4402 Answers
SOURCE: inserted cassete in wrong way in Sony camcorder CCDTRV68, not ejecting cassette Error codeC32:20
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Posted on Mar 17, 2008
Anonymous
  • 10594 Answers
SOURCE: The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Posted on Feb 26, 2009
Anonymous
SOURCE: loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Posted on May 06, 2009
Anonymous
SOURCE: I have a Sony DCR-TRV250 Digital Handycam
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Posted on Nov 17, 2009
2answers
Handy cam video 8 XR keeps ejecting cassette any ideas please
thats is because the servo mechanism chip do not detect the cassette,
when its in the housing could be a sensor or the cassette in switch or mechanism its self (missalignement.)
hope that will help you
regards alan.
2answers
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
Eject problem SOny TRV-110E
The vlatch to spring the basket (cassette holder) is easy to access on these. Many times the eject process will take place if the holder is released. After the door is removed the holder can be released by gentley raising the latch on the right side of the holder assembly. After the tape is out further checks can be made for damp drum or tension issues.
I can't eject cassette from my Canon MV800i
The mechanical of the tape loading path is misaligned, Contact any expert for mechanical adjustment of the tape loading path, No worries it will work fine again, and this would not be expensive.
Thanks for using fixya.
1helpful
2answers
Cassette removal from dead Canon MV650 Camcorder
I just solved my own problem by disassembling the camcorder until I had access to the little motor which operates the eject mechanism. It sits on the corner of the mechanics subassembly, close to the cassette. By applying about 3.5 Volts DC from a regulated power supply to the two motor contacts, it started to operate (test which direction it needs to go by trying both polarities) and lifted the cassette out of the play position and ejected it. Only since the tape was still wound around the drum, I had to use a thin tool to turn the cassette hub in order to tighten the tape a bit. Then the protective cover of the cassette closed and I could slide the cassette out of the slot by hand. Bingo!
2answers
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
2helpful
Jammed tape in Sony camcorder
There is no manual eject.
The only way is to disassemble the camera outer shell, then remove the drive mechanism and using a 4.5 V power supply power the eject mechanism.
It takes 30 min of work when you know how to do it. If you find the service manual (free somewhere in internet) it will tell you how to open the camera.
Hope this helps.
DocG4
2answers
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
1helpful
Canon UC1 8mm video camcorder
No solution..... but eager to know where one can get the battery packs and charger fir this camcorder (UC1) A 8 mm videotape is stuck within the camera housing and can not be ejected...No battery and charger available..
Where are those battery packs available f.i." SUNPAK RB-E77MF 6V 1700 mA ??
I would highly appreciate your advice
Thanks in advance
J.van Bochove
e-mail: [email protected]
Sony Handycam CCD-TRV37 Camcorder Logo
Top Sony Video Cameras Experts
Ekse
Jax Planet
Jax Planet
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
