Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter 44860 touch screen thermostat reads service heat pump system
5 Suggested Answers
Anonymous
  • 52 Answers
SOURCE: Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Posted on Jan 29, 2008
Anonymous
SOURCE: hunter thermostat 44860
Hit just to the left of the temperature and you will see a fan symbol pop up. Make sure the fan is set to the correct setting. Refresh means the fan will come on every 15 minutes or so no matter what the tempurature. Auto is usually the normal setting I think. Program mode - depends if you have programs. On mode means the fan is always on.
Posted on Oct 22, 2008
Anonymous
SOURCE: THERMOSTAT INSTALLATION
I am trying change from a Honeywell ct701A1001 to Hunter 44110 the old one has 7 wire and new one 5wires
Posted on Nov 15, 2008
Anonymous
SOURCE: heat won't come on, but
Look at your igniter on the furnace.
Posted on Jan 05, 2009
Anonymous
SOURCE: Instruction Manual for Model 44860 Hunter Thermostat
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/44002.pdf
Posted on Jan 09, 2009
Help! I can't change the temperature and the system won't turn on. All solutions are appreciated. Please include details.
The first thing to determine is if in fact the problem is in the thermostat or if the problem is in the furnace. The furnace typically provides the power source for the HVAC control system and if nothing is wanting to come on, the power to the furnace could be interrupted. Verify that condition first.
Remember most programmable thermostats have a built-in time delay possibly as much as 5 minutes and that is a long time to wait without pressing or touching another thermostat function.
Apr 25, 2015 | Hunter 44860 7-Day Programmable Touch...
How do I set my hunter thermostat so when the heat pump comes on, how to set so the thermostat and heat strips from the heat pump sinc with each other. The model number is 44860
call a service tech, this sounds complicated. To avoid using too much energy or burning down your life savings in heating bills, a certain sequence should be followed when the thermostat operates. The actual sequence will differ depending on what equipment you have available to control, as well as your location and heating and cooling loads. The money you could save by having it done right the first time will quickly pay for a service call, then keep on saving you money after that.
Feb 21, 2015 | Hunter 44860 H Univ. Touchscreen...
Auto recovery mode raises the temperature above
Hummm... how far is your Thermostat from your heater? I am reading your extensive manual but there is no mention of that distance? There was a early mention of batteries? Are yours fresh?
Is this a 'new' problem? Has it worked properly before?
Then there is this from the manual:
The installer can set SYSTEM functions once the thermostat is installed. The
default settings are shown in bold in the following list. Options are listed inside the
parentheses. Example: the default SYSTEM TYPE is CONVENTIONAL with (HEAT PUMP) as a second option. See pages 28-29 to change these settings.
Have you tried resetting your Thermostat?? Sometimes these basic 'onboard' computers get confused... especially true with lots of 'options'...
It's a little hassle to get a DIGITAL copy of your manual (I am not a Robot ~ etc) ~ but here it is:
Download manual
TROUBLESHOOTING begins at Page 68
Anthony
Dec 22, 2017 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44860 touch screen temperature override
"Hunter" says it all. Throw it out and buy a honeywell, robertshaw, or a white-rodgers. Hunter stats are notorious in the business as being problematic.
Oct 07, 2009 | Heating & Cooling
Hunter thermastat, model 44860 not working
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Jun 01, 2009 | Ruud UAMB Air Conditioner
44860 thermostat won't activate in heat mode
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Oct 20, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
109 people viewed this question
Top Hunter Dryers Experts
Joe Paxton
Level 1 Expert
Paul Bade
Marvin
Marvin
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
