Question about HP PSC 1315 All-In-One InkJet Printer
Printer Won't Take Paper
Every time I try to print something, an error comes up saying to make sure there is enough paper. Even if there is paper, the printer won't take the paper and it won't print. The "Check Paper" light keeps flashing.
Help?
Posted by fhfh on
  • Anonymous Mar 18, 2014
    Sometimes the paper when it is coming out of the printer after printing it catches and makes a teardrop out of the paper and then the next page might come out flat and the next one will teardrop. This causes the paper to fill up the output slot fast. Paper goes all over the place and print is out of order.
  • Anonymous Mar 21, 2014
    not clabrating correctly paper takes after pressing two time but not not coming out & not printing if we starts normally the station 2 & ready blinks and not taking the paper
CheckitRight
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,363 Answers
I beleive that machine has two slots to put paper, try moving the tray to the other slot, for some reason it may have defaulted to that tray.
Posted on Nov 08, 2007
Anonymous
I cannot print because the paper will not feed down into the printer. Will i have to get anoter printer
Posted on Aug 03, 2009
Cp305d paper size error
It may be a sensor problem When you reseat the tray it may not be actuating the paper size switches correctly. Check the paper tray and make sure that there aren't any missing or broken/bent tabs on it.
Mar 17, 2014 | Office Equipment & Supplies
Printer says "clear carriage jam".
hi gaperk52,
iam koaslosa and i will be assisting you today,
Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer and wait for the carriage to slide over
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Thanks and please click the green ACCEPT button if you are satisfied with my answer.
Thanks,
and if this fails look a small scrap of something stuck in the carriage path a paper or something!!!!!
Jun 27, 2011 | HP Officejet J5780 All-In-One InkJet...
Hi, the printer is saying paper jam when there isn't one. it won't scan or copy from the glass and will copy from the paper feed but only 1 copy and then comes up paper jam again. if you turn the...
there are many spring loaded switches within a printer that monitor the location of a sheet of paper, it is possible that one of these switches got stuck and is the cause of your problem. Printers can be quite difficult to work on, so I would recommend taking it to a local repair shop to have it looked at. If the switch is simply stuck it may be a quick and easy repair.
Another thing to look at is to make sure all of the rollers that feed the paper through your printer are moving, if one is stuck it could be giving you the same error.
May 05, 2011 | Office Equipment & Supplies
I can't get my printer to print. The error
It says paper jam because the paper bar (located just before the paper exit) can't (or does it very badly) roll. It can be caused by a lot of things that have fallen inside the printer. Open it and try to see what's blocking the bar
Oct 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Dell photo aio Printer says Error:2200 Will only feed paper half
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Dell 926 All-In-One InkJet Printer
Can't print in black ink.
Wipe the cartridge of cotton,don't use water.Make sure the black is not empty.
May 19, 2009 | HP PSC 2175 All-In-One InkJet Printer
Computer keeps saying ''paper out'' or ''not loaded properly''
It sounds like your sensor, clean it with a dry cloth, then check to make sure you don't have too much paper in at one time thus preventing the stack from engaging the sensor. If still a problem, disconnect all wires including power and re try, it sounds like something is hung up, it is usually dirt. Then it isn't allowing the paper to fall low enough to be picked up by the printer.
May 14, 2009 | Office Equipment & Supplies
LSU error message
Apr 27, 2009 | Xerox WorkCentre 220 All-In-One Laser...
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
HP PSC 1315 All-In-One InkJet Printer Logo
602 people viewed this question
Ekse
efs_perpends
efs_perpends
