Question about Leviton Electrical Supplies
Wiring diagram for 3 way 2 socket lamp
Lamp socket wiring diagram
guitar zan
    Habit-Forming:
  • 141 Answers
Where is the switch located? If you buy a replacement switch at Home Depot it usually comes with a diagram that shows you how to wire it. If the switch is built into the light socket just replace the socket the switch is included.
Posted on Jul 30, 2014
Front directionals,i need to use led 2 filament lamps to prevent melting bulb socket, do I need a resistor on both blue and green wire
That looks like some internal issue, try reaching the wiring systems. You can try getting a manual for your model here. They also sell wiring diagrams I guess. Here's the link Best Manuals
All the best !
Changing backup bulbs on 2005 buick rendevous
TAIL LAMP ASSEMBLY AND /OR BACKUP, SIDEMARKER, STOP, TURN SIGNAL BULB REPLACEMENT
REMOVAL PROCEDURE
1. Open the liftgate.
2. Remove the screws from the tail amp.
3. Slide the tail lamp rearward in order to disengage it from the retainers on the rear body panel.
4. Disconnect the electrical connector from the tail lamp wiring harness.
5. Remove the tail lamp and side marker lamp sockets from the tail lamp, depressing the locking tab and turning counterclockwise.
6. Remove the bulbs from the tail lamp and the side marker lamp sockets, if replacing the bulbs.
INSTALLATION PROCEDURE
1. Install the bulbs to the tail lamp and side marker lamp sockets, if removed.
2. Install the tail lamp and side marker lamp sockets to the tail lamp, turning clockwise until the locking tab is fully seated.
3. Connect the tail lamp electrical connector to the wiring harness.
4. Position the tail lamp retainer slots to the tabs on the rear body panel.
5. Install the tail lamp to the rear body panel, pressing into place until fully seated.
6. Install the tail lamp screws to the Taillamp.
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the tail lamp screws to 2 N.m (18 lb in).
7. Close the liftgate.
2answers
2answers
1992 honda integra horn fuse blows after applying brakes
Honda makes the Integra but it uses the Acura name in the US.
According to the wiring diagram the brake lights and horn are on the same circuit. So I would check the bulbs and sockets for a short.
The brake light switch also involves the cruise control system.
How do i replac the interior light on my frigidaire fmv156dc microwave?
We have the service manual and have uploaded it to our site here to help you.
From page 33:
OVEN LAMP and Lamp Socket REMOVAL
1. Disconnect the power supply cord, remove the oven from
the wall and remove the outer case. (Refer to procedure
of "Removal of Oven from Wall" and "Outer
Case removal ".). And proceed as follows.
2. Open the door and block it open.
3. To discharge the high voltage capacitor, wait for 60
seconds.
4. Remove the three (3) screws holding the hood intake duct
R to the oven cavity top plate, the oven cavity front flange
and the fan duct. And remove the hood intake duct R.
5. Turn the lamp socket and release it from the magnetron
duct.
6. Screw the oven lamp off from the lamp socket.
7. Now, the oven lamp is free.
8. Pull the wire leads from the oven lamp socket by pushing
the terminal hole of the oven lamp socket with the small
flat type screw driver.
9. Now, the oven lamp socket is free.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
1helpful
2answers
I need a diagram to install a Westinghouse 3-way light switch (#77052) on a lighting fixture on the bottom of a ceiling fan. I did not do the removal of the light fixture so I don't know how it was wired...
If by a 3-way switch, you mean a switch with 4 steps of brilliance: off, low, medium, and high when used with a 3-way bulb. The black wire of the switch is connected to incoming power wiring hot wire. Most often also black. The red switch wire connects to the center contact of the lamp socket. The blue wire connects to the small pin connection that is physically between the center connection and the screw shell of the lamp socket. The screw shell is connected to the incoming white wire of the house wiring.
2helpful
I need diagrams for the fuse boxes in the dash and engine compartment so I can find the fuse/relay I need to replace. My dash lights, tail lights and windsheild wipers are out.
Hi
There are a couple of wiring diagram and manual available on the net. The relay you are talking about is the park lamp relay which supplies power to the tail lamps, license plate lights and both front and rear park lamps. If the park and plate lights are working the light switch, relay and supply power are good. You need to verify for a broken brown wire to the tail lamps (assuming the sockets, lamps and grounds on both tail lights are good) .If none of the lamps are working then the 15A fuse number 3, the light switch or the park lamp relay could be bad (note different contact in the main light switch work the other lights)
You can find a wiring diagram and component location at
www.autozone.com and http://www.pdfgeni.com/book/1998-ford-ranger-wiring-diagram-pdf.html
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
2answers
7helpful
2answers
Need wiring diagram for three lamp flouescent fixture using a four lamp electronic ballast
i have a light fixture with two single pin T96 bulbs, black and white wire go to one end of the fixture, two red wires come out of other end - one wire on each socket, but a have a ballast with two blue wires and a red wire coming out the same end of ballast, how do i wire this up? thanks Charlie
4helpful
Fitting a towbar for a caravan with 13pin europlug
black socket, black 7 core wire
pin 1 yellow left indicator
pin 2 blue, rear fog light
pin 3 white earth
pin 4 green right indicator
pin 5 brown right side/tail light
pin 6 red brake lights
pin 7 black left side/tail light
Grey socket grey 7 core wiring
pin 1 yellow, reverse
pin 2 blue, supplementary feed (ignition)
pin 3 white, earth
pin 4 green live feed (battery +)
pin 5 brown not connected
pin 6 red supplementary feed (ignition)
Pin 7 black earth
On the discovery there is a purpose made plug behind the panel on the drivers side rear, behind the rear lamp
i think the relay you have bought is for lamp failure you just need a normal 4 pin 30 amp relay.
Good luck Davelee
Electrical Supplies Logo
Top Leviton Electrical Supplies Experts
john h
Mike
Gil Shultz
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
