Not - one hose length, but 3-4 feet away from the in pool cleaning head.
The first Polaris hose length is the softer clear hose and that should be cut at a length that equals the deepest part of the pool. So if your pool is 8' deep, that is WAY Too far away from the head.
It it is designed to pull the unit out of any predicaments that may render the unit 'stuck'.
Should be located one hose length back from cleaner head. Sort of tear drop shaped in-line with the hose. It has a gear inside that changes water flow so the unit will lift off pool bottom every couple minutes in case it gets stuck in a corner.
