Question about Blaupunkt BLA32/147 32" LED TV 1920x1080, 50 Hz, Freeview, HDTV
Why when turning on blaupunkt 1080p led hd tv i only get a black screen there is start up menu
I cant enter and menu or see any set up on the screen, so I am at a loss what to do I have tried to find the manual but having problems finding it on the internet , the easy start up guide states it should appear straight away or press menu 8888 but nothing happens
Posted by jon hyland on
Anthony Gonzales
    Sergeant:
    Champion:
  • 267 Answers
If you tap "gently" on the front screen do you see whiteish color?
If no you have a problem with the set. probable power supply issue.
If you do then press menu. If you don't see the menu on screen, probable control board issue or lvds board. Time for a tech.
Posted on Jul 29, 2014
Having problems setting my email address for notifications
The @ sign you will find it pressing the button for special characters on the on screen keyboard menu.
Mar 13, 2014 | SWANN Home Security
MA-600 cash Register cant alter commercial message
Ok. So go inside the Menu.
- Press Enter or 1, it should select Messages
- Press Enter or 1, it should select Commercial Messages, and display the first line of the previous message.
- Press Enter and type the first line of your commercial message.
- Validate with Enter, and then (Enter again ?) or just start typing the second line.
- Validate with (double ?) Enter, then type the third line.
- Validate with (double ?) Enter. A long receipt should be printed display should return to Main Menu screen.
Mar 09, 2014 | Computers & Internet
Trying to tune in my t v 37722hd no manual
If you are connected to the sets coax or cable fitting and not using a box go into the customer menu for set up and select antenna if using antenna and not cable.
With set hooked and on in menu find autoprogram and engage it.
If no channels found use remote and directly with keyboard enter a channel like 03 and see if reception.
Let me know what is connected and what you have tried. A brand and confirmation of the model number would help.
Mar 13, 2012 | Televison & Video
Cant get internet settings
For most cell phone networks and operators, Internet and messaging settings come pre-installed on your phone. You can then start using the Internet and send messages right away.
To download Internet and messaging settings:
  1. From the Home screen, tap the Application screens icon.
  2. Find and tap Settings > Sony Ericsson >Internet settings > Accept.
To configure Internet settings manually:
  2. Find and tap Settings > Wireless & networks > Mobile networks > Access Point Names.
  3. Press the Menu key.
  4. Tap New APN.
  5. Tap Name and enter the name of the network profile you want to create, then tap OK.
  6. Tap APN and enter the access point name, then tap OK.
  7. Tap and enter all other information required by your network operator.
  8. Press the Menu key and tap Save.
Note: Contact your network operator for detailed information about your network settings.
Dec 02, 2011 | Sony Ericsson Walkman® W995 Cell Phone
I have changed the setings some how i have disabled some thing now my set top box wont work its a aiko stb255 when i switched it on it just flashes up for a second and then its just a blank screen i cant...
As the manual says "please make sure your TV set can support Progressive format before you select YPbPr Mode or you will can not see picture on TVset" (sic).
To get back from a blank screen:
1 unplug the STB to reset the menu positions to default (because you will be making menu selections blind)
2 plug unit back in and turn it on and use the remote to press in order:
Menu (TV sound will be muted because the menu is now displayed, even though you cannot see it)
Down
Down
Enter
Down
Enter
Down
Down
Down
Right (or Left)
You should then get a picture. Leave the picture setting at CVBS (and don't touch it again lol)
For visual cues on what you are trying to do, look at page 8 of the manual.
Feb 06, 2010 | Televison & Video
Cant enter codes in Eurovox ex1000 sl
if you need to manually enter the keys a different procedure is required to previous versions of the firmware.
To access the key entry screen try the following:
On the remote press "Menu".
Highlight "Language Settings" and press "OK".
Highlight "1st audio lang" or "2nd audio lang" or "Subtitle lang" NOT "Menu language", then press the buttons 1,9,6,8 in order.
The key entry screen should now be visible.
Use the left/right arrow keys or "FAV" button to find the "NagraVision" screen which contains the keys for UK service providers.
to reveal the "Emulation" and "EMM Capture" Highlight "Menu language"
Aug 21, 2009 | StarTech.com StarView SV211K 2-port KVM...
Wuz n menu settings, hit wrong button, now only hve rolling pix!
you pressed the color system format button/settings.on the remote press the P/N which means pal/secam and ntsc.press it several times or until you get a steady picture.when its black and white then you can press the set-up or menu button to correct your settings.
May 18, 2009 | Cyberhome CH-DVD 300 DVD Player
Sigmatel s4
U can find a house symbol on the bottom of your touch screen. Jus click tat and u find menu options.In tat select settings and select dual sim settings. There select Dual Sim
Aug 14, 2008 | Handmark Software MobileLists (950142) for...
Ilo DVDR05
To change from p-scan back to i-scan with no video picture, mu1 model: 1.turn dvd on with no disc, wait 10 sec. 2.press "setup" 3.press "down arrow"(selects audio/video) 4.press "enter" (selects audio/video menu) 5.press "down arrow" 4 times (selects scan mode) 6.press "right arrow" (selects scan menu) 7.press "up arrow" (selects interlace mode) 8.press "enter" (should see picture) Or find a tv with p-scan capability.
Nov 30, 2006 | iLO DVDR05 DVD Recorder
I cant get back to s-video mode.....:(
Sep 23, 2006 | iLO DVDR05 DVD Recorder
Blaupunkt BLA32/147 32" LED TV 1920x1080, 50 Hz, Freeview, HDTV Logo
862 people viewed this question
Top Blaupunkt Televison & Video Experts
Marvin
Marvin
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
