Philips 42PF5520 42 in. EDTV-Ready Plasma Television Logo
A
Anonymous Posted on Jul 29, 2014
Philips instruction manual
Why does my tv not switch on no output from tv flashing red light tv remote switches tv on for a second then screen goes blank no sound or picture i have manged to get a picture on screen
conley_ted
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 29, 2014
conley_ted
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
212
Points
YOU NEED TO REPLACE BAD CAPS ON MAIN POWER BOARD philips instruction manual - 4167e67a-4c77-4574-ae00-a26d52afd0ea.jpg
5 Related Answers
Anonymous
  • Posted on Jan 31, 2008
SOURCE: Red light flashing
ctf1800,
I would love to have that service manual. My Philips 37PF7320A died 4 days ago with the typical 1-4 blinking lights. The fuses are fine but I found a 100 ohm 1/4 w resistor that was dead and replaced it, but no change. Now I have looked closer at the "dead" resistor and after the brown-black-brown and there is a poorly applied green band before the gold one, so I'm not sure what I have. I guess I need to get a high resistance tester off eBay.
[email protected]
A
Anonymous
  • Posted on Apr 13, 2008
SOURCE: Philips 42 in. Plasma shut down
Thank god we purchases the ADVANCED extended warrenty. This tv has been nothing but problems.
Fuzzy picture, picture shutting off after 20 sec coming back on and now blog of colors shut off never to come on again. 7 blinking red lights on the front. Waiting for the repair man again.......
Anonymous
  • Posted on Feb 08, 2009
SOURCE: Philips Plasma NO LIFE
I had the same problem (with 42FD9954/17S) that when turned on the unit, the green LED turned off and came back to red again some time later. I kept turning it on and once it went to a clicking relay sound and blinking green LED with it. It did that for a while and stayed turned on. I noticed that it is temperature sensitive. Colder the room is more often does it. Used a hair dryer and blown hot air into the unit at the left bottom grills. It helped and started to tun on quicker. Later it has deteriorated so bad that I took it a part and after several ice spraying test showed that on the middle big board (power board) there was an electrolyte condenser went bad. It is the one one which is at the middle, bottom center of the board near the fixing screw. There are two of them (cylindrical objects). The left one was the culprit. However when I fixed it, it turns on immediately but goes blinking red after that. Phillips say it is a static discharge problem. I might blown something when soldering the parts. I don't know what. Any ideas?
doc2r
  • Posted on Nov 07, 2009
SOURCE: 42PF9966/10 - PHILIPS - UNIT NOT WORKING, NO PICTURE, PWR OK
Having the same tv and problem for a year ago.
I disconnect the main powercord from wall socket
and wait for 2 min. and connect again.
Problem solved. Its not a fix, but maybe it helps?
freetek
Steve Allison
  • 5569 Answers
  • Posted on Nov 22, 2009
SOURCE: Philips lcd tv 42pfl5432d/37 no picture
If you feel you have isolated the problem board, you might check here for a replacement:
Jimmy's Parts
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
1helpful
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
2helpful
3answers
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
2helpful
Returns to standby
Green flashing 3 times = digital DC - DC converter fault
Red flashing 3 times = scan circuit fault
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
