Lexmark Ms810, Ms811, Ms812, Mx710, Mx711 550-Sheet Tray Logo
T
T Immer Posted on Jul 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer Question: How would one go about disabling the separation page on a Lexmark MS810?
How would I disable the separation page on a Lexmark MS810?
Lars-Eirik
Level 2:
  • Expert 65 Answers
  • Posted on Aug 12, 2014
Lars-Eirik
Expert
Level 2:
Answers
65
Questions
0
Helped
31497
Points
105
Hi. It's most likely a driver issue. If you look through the driver settings, you will probably find an option for turning separation pages on and off. If you can't find the setting in the driver, look for it in the printers setup menu.
Good luck..
Power error message 126.01
usually this problem lexmark ms810 series device fuser problem .change fuser is problem solved. cihat alt?n PR?NTER TECHN?CAL SPEC?AL?ST-TURKEY
1helpful
Why does my printer put through an extra blank page after printing?
Yout have to disable SEPARATOR PAGE under printer properties
1. Select Start.
2. Select Settings.
3. Select Printers and Faxes.
4. Highlight the appropriate HP LaserJet printer icon.
5. Right-click on the highlighted printer icon and select Properties from the Advanced tab.
6. In the Advanced tab, select the Separator Page button.
7. Delete the location for the separator page.
8. Select OK.
1helpful
Lexmark x6575 I want to disable the wireless function
you can take out the white box where the black antenna is behind the printer. It's the wireless network adapter of the printer. It might be hard but it can be pulled out off the printer. Hope this helps.
Printing problem
ISSUE: A blank page prints after every print job using an HP LaserJet series printer. SOLUTION: A separator page may be turned on in the printer driver, within the application, or on the network. Try printing from several applications. If a page prints out in only one application, that application may have a summary page selected to print out. If a page prints out from different applications, a separator page may be turned on in Windows or on the network. Use the following sections to turn off separator pages. Windows 95/98/Me Follow these steps to turn off the separator page in Windows 95/98/Me:
  1. Select Start .
  2. Select Settings .
  3. Select Printers .
  5. Select File .
  6. Select Properties .
  7. In the section labeled Separator Page, select None .
  8. Click Apply .
  9. Click OK .
Windows NT 4.0/2000 Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  5. Select File .
  7. In the Advanced tab, select the Separator Page button.
  8. Delete the location for the separator page.
  9. Select OK .
Windows XP Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  3. Select Printers and Faxes .
  8. Select OK .
Software or applications See documentation for the specific application that is printing a separator page. The following steps are an example of how to turn off the summary page in Microsoft(R) Word 97:
  1. Open Word 97 .
  2. Select File .
  3. Select Print .
  4. Select Options .
  5. Deselect Document Properties in the Include with Document section.
  6. Select OK .
Novell environments Banner pages can be sent to the printer in several different ways in a Novell environment. The following instructions detail several ways to disable the banner page. NOTE: Banner pages can also be sent from the HP Jetdirect device itself. This page can be enabled and disabled through a telnet session to the HP Jetdirect device. The telnet banner will only print in an lpd/unix ® environment. Novell's Capture Command To disable a banner page using a Novell DOS capture command at a system prompt, type the following commands: capture L=x Q=queuename NFF NB NT TI=x where:
  • L = x -- The value of x would be 1, 2 or 3 depending on the lpt port being used.
  • Q = queuename - The value of the queuename would be the Novell queue setup for this printer.
  • NFF -- No form feed.
  • NB -- No Banner.
  • NT -- No Tabs
  • TI = x -- The value of x would be the timeout amount in seconds. NOTE: If the client workstation is restarted, and if a capture command is part of a login script that is being used, these settings will be reset.
Printer Properties The banner page for Novell networks can also be enabled or disabled in the Printer Properties using the following steps:
  1. To open the Printers Folder ; click Start , Settings, and Printers .
  2. Right-click the appropriate HP LaserJet printer icon and select Properties .
  3. Select the Printer Settings , or Capture Settings tab. The banner page can be enabled or disabled here.
NetWare Clients Follow these steps to disable the banner page for Novell NetWare clients:
  1. Right-click Network Neighborhood and select Properties .
  2. Select the Configuration tab in the Network window.
  3. Highlight Novell NetWare Client and select Properties .
  4. Select the Default Capture tab. The banner can be enabled or disabled here.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
