Assuming the basics have been signed off, the usual reason that a set will not fire up is a power supply problem. In sets like yours the supply comes from the transistor that supplies the screen with pulses and hence high voltage. In short with a set as old as this I personally would not be bothered getting it repaired. You could probably find someone giving a working set away for free on numerous local selling websites.
SOURCE: No picture, standby light blinking
MOST LIKELY THE ERROR 3 IS THE 200V LINE TO THE CRT DRIVE IC.IC702. ON THE CRT PC BOARD. IT ALSO COULD HAVE GONE OUT IF YOU HAVE HEAVY USAGE ON THE SET 8-12 HRS A DAY. THE CTR COULD SHOT AND TAKE OUT THE I.C. AS FOR IS IT WORTH FIXING, THEY DON'T MAKE CRT TV'S ANY MORE AND THE NEW SETS SEEM TO HAVE A LOT OF PROBLEMS.
DON..
SOURCE: Is is worth getting repaired?
Power supply mnay be out. Yes, get an essimate if you like first, but if it's less than 8 years old-get it fixed.
SOURCE: blinking 8 times
this kind of tv have a good picture if you use the component input
most sure you have problems on the zero cross detector or the flyback
I did one like this one for 200.00 if we need the flyback goes up to 275.00
SOURCE: Red LED light blinks 7 times when the set is turned on; no pictur
if you have the circuit diagram of your tv,check the horizontal polarisation IC closer to the line transformer and replace it.If it doesn't work,send the question again.
SOURCE: tv won't stay on it shuts off as soon as I
Most Sony's usually always have bad regulator ics. Depending on your model, could be a mcz3001 or str ic or mxoa ic. Check for 160v across the main capacitor for 160v to see if your power supply is working. Do not use chassis ground. Use the ground on the cap.
