My sister pulled the door open before it was finished and broke something in the lock mechanism. I then unscrewed the little lock thing on the washing machine. Heard something fall down and can not attach the screws again. The machine didn't lock before but would still run. I found that very worrying wig kids in the house. Now it doesn't even start.
SOURCE: My washer won't start
did you sort you problem with your machine ? as my machine has identical fault [email protected]
SOURCE: DOOR WONT OPEN
Hi. Try un-pluging machine,take off top lid slide your hand down between casing and drum until you find lock, then try flicking door casp while trying to open door gentely. when open replace door lock before using again.
Slim jim
SOURCE: DOOR CATCH BROKEN - HOW TO OPEN DOOR FROM INSIDE THE MACHINE
Select washing machine at link below to find door handle
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
SOURCE: door will not open. lock handle floppy.
take top off and see if you can feel for the door peg sticking thro the interlock and operate by hand.
also, you can chew away the door handle and operate the door peg with a small screwdriver.
the door handle kit will need replacing anyway
