Polaroid i830 Digital Camera Logo
A
Anonymous Posted on Jul 29, 2014
I would like to delete the date/time stamp so it will never show up
ELECTRICKSUSA
Level 2:
Sergeant:
  • Expert 282 Answers
  • Posted on Jul 29, 2014
ELECTRICKSUSA
Expert
Level 2:
Sergeant:
Answers
282
Questions
0
Helped
91245
Points
746
Its in system settings
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
1 Related Answer
dnewcombe1
Dana Newcombe
  • 1564 Answers
  • Posted on Nov 22, 2009
SOURCE: polaroid a520 will not keep the date
You may want to set the factory defaults by going into the main maenu.
1helpful
2answers
How do I completely remove the date/time stamp from Canon AS1100 IS so it doesn't show on my photos?
  1. Step 1: Load the image. Open the image that you wish to remove the date stamp from.
  2. Step 2: Select the date/time stamp. Zoom in on the area with the date and time stamp, and then mark it with marker or any other selection tool.
  3. Step 3: Run the restoration process.
https://www.besanttechnologies.com/training-courses/data-science-training-in-bangalore
6helpful
Need to email pictures showing the date and time stamp on panasonic dmc fh27
Turn on the [Date Stamp] setting in the [Rec] menu. See page 83 of this manual.
How do I get time date stamp to show on video footage taken with JVC Everio GZ-HD620
The AVCHD file contains the time date stamp as subtitle track. Any player that can show subtitles can show the time/date stamp (I use Videolan Player).
Usually, after downloading the avchd files to my computer, i do an OCR on the sub file and convert it to .srt, as well as conver the avchd into .mkv and include teh subtitle file into it.
Remove date stamp from canon s100 photos
You can remove date/time stamp from photos using Inpaint
1helpful
2answers
I want to delete multiple pictures on my camera, and also remove the date while taking pictures.
Delete Pictures (page 79 from User Manual)
Remove Date (also check page 77)
Hope this helps (remember to rate and comment this answer).
10helpful
Show/print date stamp on my photos
In order to imprint the date stamp on photos, the photo size (L, M1, M2, M3, S, Postcard) must be set to Postcard, and in the recording menu the "Date Stamp" option must be set to Date or Date & Time.
3helpful
2answers
Displaying time and date when printing
The date/time cannot be deleted once it is embedded in the image. To turn off the date/time deselect the date/time stamping by following procedure:
These instructions explain how to insert the date in images.
attention:
  • The [Date Stamp] cannot be deleted from the image data once it has been recorded because the date is written in as an image.
  • When selecting [Date Stamp] , [Recording Pixels] is set to 1600 x 1200 pixels and the compression (image quality) to [Fine].
  • When the shooting mode is set to <Movie> (g0029623.gif), settings for inserting the date and time cannot be made.
  • The following explanations are provided based on the assumption that the [Shooting Mode] is set to <Program AE> (g0034813.gif).
1. Press the <Power> button on the camera.
2. Press the <FUNC./SET> (g0046915.gif) button.
3. A screen like the one below will appear on the monitor.
Select g0013174.gif [Date Stamp] (g0013171.gif) in the [Recording Pixels] section g0013173.gif.
g0013176.gif Press the <MENU> (g0046624.gif) button.
4. A screen like the one below will appear on the monitor.
g0013173.gif Operate the <directional buttons> left or right to select [Date Stamp] and set it to [Date] or [Date & Time].
g0013174.gif Press the <MENU> (g0046624.gif) button.
5. Press the <FUNC./SET> (g0046915.gif) button.
6. Make sure that the [Date Stamp] is set and the following screen will appear with the icon (g0013164.gif) in the lower-left corner of the screen.
7. When shooting with this setting, the date will be embedded in the image as shown below.
g0013173.gif [Date]
g0013174.gif [Date & Time]
warning: The date, its font and color, and the position where it is displayed cannot be changed. Also, dates and times recorded with [Date Stamp] cannot be deleted.
If you need a manual for the A480, you can download it from:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=18155
Please rate this solution. Thanks.
How to delete the date from photos
Cameras normally have a setting where you can turn the date stamp on or off. Just browse through the menu. It will be there somewhere. In he case of the photos already taken with the date stamp you will be able to remove it with the brush tool in Photoshop.
Hope this helps!
Cheers
Date and timestamps
Is there a way to select a group of pictures on the camera and give them all the same date and/or time stamp?
No
Each JPG will show the date on which it was taken, but not on the photo, it will show it on your computer under the column "date picture taken"
Show the Date stamp on the picture
One reason why the date stamp is not showing would be that you have not set the system date/time. The date/time resets everytime you take out the battery. Please go to this link and download the userguide... http://alpha02u.c-wss.com/inc/ApplServlet?SV=WWUCA900 file name : PSS500IXUS500CUG-EN.pdf ...Go to page 26 which will tell you how to set the date/time and then go to page 109,113 for the date/time to be displayed on the photographs. Please tell me if this helps
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
