SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
SOURCE: Kohler Confident 7 model 7CCKM22 generator
sounds like a relay should be latching one it has started
Testimonial: "Thanks. Will take your advise to my electronic wiz-kid friend who has the generator regulator, & is going to run tests. Will let you know the outcome."
SOURCE: generator quit working
I have fixed Dozens of generators and around 70-80% of starting- none running problems are due to either A) Debris soil dust or Water in the Carb (don't ask me where it comes from but it gets through or B) Jets blocked with same or just Electrolytic Crud, dissimilar metals Brass Jet in Allot Carb etc. First step drain tank & carburettor bowl (screw or bolt in bottom usually, run a needle or similar though the main jet (up in centre in Honda type designs) when sure all is clear, fit a $1-$2 small paper in-line fuel filter and try again. The standard filters are too coarse and let in fine dust-rust all the time, hope this helps always works for me, Good Luck from England!
