Question about Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair
Why is only one speaker working in my s10 - Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair
Alex Hernandez
    New Friend:
  • 4 Answers
Look for a broken wire first. the speaker itself may be blown or an internal problem with the radio. either of which would require replacement.
Posted on Jul 29, 2014
SK-S10 with MP3 and card....How do you get it to work?....Is there an opp's manuel?
As I understand, SK-S10 is a Bluetooth speaker. If your MP3 player is not Bluetooth-enabled (and I believe very few are), you cannot use the SK-S10 with the MP3 player. But you can use it (via Bluetooth) with your cellphone, tablet, computer (if Bluetooth-enabled) and with any other Bluetooth-enabled media device.
Nov 17, 2014 | Audio Players & Recorders
Does the wyse sxo have a speaker
No, I do not believe the "S" series (S10, S30, S50 & S90) have any speakers.
Mar 01, 2013 | WYSE Winterm S30 Network Terminal
Radio wiring diagram for a 1998 chevy s10
1998 Chevrolet S10 Pickup Stereo Radio Wiring Diagram.
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 4′ x 10′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Nov 11, 2009 | 1998 Chevrolet S-10 Pickup
Need wiring diagrams from a 1994 chevy s10 to a pioneer deh-p3000
its not a big problem try another speaker from the right side. if not work. check fuse and the wire. just follow the wire where its connected. if no fuse found. the problem is in the amplifier IC. change it if speaker from right side is not burned yet. thanks.
Jun 07, 2009 | Pioneer DEH-P3000 CD Player
SURROUND FEATURE WONT WORK ERROR S10 WOULD APPEAR ON DISPLAY
Press and hold the VIDEO-1 button then press the SPEAKER A button and hold until "clear" is displayed. Then re-enter your setup menu, enable your surround speakers and if there is a decode priority select "PCM."
If your problems continue, contact Onkyo.
May 08, 2009 | Onkyo TX-DS838 Receiver
Error s10
Did it ever work properly? If not, let's get down to basics and set it up for the simplest configuration it can have: FM source in stereo with front left and right speakers, no Surround Mode, no DSP, no Tape Monitor, no Mute, Volume not turned all the way down. Does that work?
Do you have Surround Speakers defined in System Setup A? If not, only Dolby Surround or Off are valid Surround Modes.
Is T2 Monitor indicator lit? Press the Tape-2 Monitor.
Is there acceptable sound other than during Speaker testing? NO? Is MUTE On?
Apr 29, 2009 | Onkyo TX-DS838 Receiver
Clestion S10 Sub not working
Instead of connecting it to the sub output, try it on the L or R output of your amp.
This will eliminate the Denon.
If this fails, you need to test the loudspeaker driver unit whilst disconnected from the sub amp. Use a 1.5v cell (AA or bigger) connect using croc leads to the speaker's terminals. If the speaker is OK, you should hear a click. If you hear nothing, the speaker unit is faulty.
Jan 25, 2009 | Celestion S10 Subwoofer
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair Logo
132 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
 Russ Hill
Russ Hill
gbob59
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
