Question about Karcher K2.26 Electric Power Washer
Where is the fuse located into the machine.?
Want to change the blown fuse , but do not know where it is.
Mikey
    Top Expert:
  • Karcher Master
  • 6,499 Answers
In the mains plug!
Posted on May 27, 2020
I wanna know how to change a fuse for a saturn aura 2007.
What fuse ? Regular mini fuse ? Just pull it out with the fuse puller tool located in the fuse box compartment . Replace with same number fuse . 5,10 , 20 , 25 etc.. what ever it is . How To Safely Change Blown Fuse
Feb 02, 2017 | Saturn Cars & Trucks
How do I change the fuses?
Remove the fuse box cover remove old place new fuse of same size. Step by Step:
  1. Locate your car's fuse panel.
  2. Take off the fuse panel's cover.
  3. Locate the blown fuse.
  4. Remove the broken fuse.
  5. Insert a replacement fuse of the correct amperage-make note of the fuse panel and your owner's manual on this one.
  6. You do keep a few extra fuses of various amperage in your glove box.
How to Find and Replace Blown Fuse in Your Car or Truck
Changing Fuse DMV org
How to Change Vehicle Fuses
How to Change Car Fuse in 8 Easy Steps
May 30, 2016 | Cars & Trucks
I got a malibu 2010 my radio fuse is blown i do not know which box it is in to change it
The radio fuse is in the fuse compartment located on the passenger side of the console. Remove the cover on the console and then remove the fuse box cover, search out the radio fuse and inspect to see if it has blown.
Jul 05, 2014 | 2010 Chevrolet Malibu LS
No power, even new A5 fuse slotted in
check the fuse located in the male plug of the power supply, if problem still going on, replace the power supply...
Jan 26, 2014 | Brother MFC-7820N Printer
97subaru legacy, and both the front and rear lighters aren't working, and would like to know which and whre the fuses are i need to change The location of the fuses
hi the fuses are located under the drivers side (jdm version) on the side of panel under a black plastic cover, just look for the blown one as the locations are all written in japenese
Apr 06, 2012 | 1997 Subaru Legacy
2003 mitsubishi spyder horn dont work
In many cases, a blown fuse is the reason a horn does not work. Locate your fuse box. The specific location can be found inside your owner's manual. Inside of the fuse panel, you will find a diagram of the fuses. One of the fuses will say Horn. I recommend changing the fuse. If you do not know a lot about changing fuses, a auto parts store should be able to help you out. Hope this helps!
Apr 23, 2011 | 2003 Mitsubishi Eclipse Spyder
Ihave a whirlpool electric dryer that just stopped working. i was told there is a fuse i need to change. can you tell me which fuse and where it is located?
If you look in the back inside of the machine where the plugin is. There is the power supply/high-voltage transformer. THis provides power to the unit. Next to it should be a fuse. Either a ceramic or a glass bus type fuse. There should be a thin wire inside of the fuse. The wires can break and then the fuse is no longer any good.
Feb 07, 2010 | Washing Machines
I changed the heating element after water had gotten into the dryer. It still isn't heating. Is there anything else I can change?
In most cases, a failure to heat is caused by a blown thermal fuse or high limit thermostat. Usually it is the fuse, but the fuse may be blown due to a defective thermostat. To find the location on yourspecific machine (and purchase the parts) try www.appliancepartspros.com To test the fuse, WITH THE MACHINE UNPLUGGED, put an ohmmeter or continuity tester across the fuse with it's wires unhooked. It should have continuity. If it is open, replace it. If the thermal fuse blows, it is fairly common to find the dryer vent partially blocked as well. Make sure it is clear. Thermal fuses are fairly cheap, but you don't want to have to replace it every other week.
Jan 03, 2010 | Dryers
Can't locate 1992 civic parking fuse..
the fuse box is generally located between the drivers door and the dash board just check all the fuses until you find a blown one
Mar 26, 2009 | 1992 Honda Civic
Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Sep 16, 2008 | LG WFT1071TP Top Load Washer
Karcher K2.26 Electric Power Washer Logo
297 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
Bruce Robin
Are you a Karcher Garden Expert? Answer questions, earn points and help others
