Question about Konica Minolta bizhub Office Equipment & Supplies
I have a problem with a bizhub C203 what can i do?
It has stripes all over the image
Posted by emilio pp on
Adorjani Laszlo
  • Konica Minolta Master
  • 1,316 Answers
Verify the problem is in the imaging units or the transfer belt units.Remove the transfer unit and clean on vacuum cleaner the transfer belt cleaning blade.If you see the stripes on transfer belt after cleaning is work normally.If not observ stripes on transfer belt the problem is located in imaging unit.Enter in service mode :Press Utility key-Meter count- Details-Stop 00-Stop01 Select Test mode-select Gradation test pattern and select the Cyan press Start,after select Magenta Press Start,Yellow +Start,Black4+Start.If any color test pattern is not graduate the problem located to image unit when is not graduaTE.
i have a problem with a bizhub C203 what can i do? - d0083ecd-a427-4d22-9a72-08abae544955.jpg
f25ba8ce-4040-4d61-8f02-f14eeaai have a problem with a bizhub C203 what can i do? - 23f95ec7-44c1-47cb-83da-47f225eb425e.jpgr /><img src=
Posted on Jul 30, 2014
Testimonial: "I allready changed imaging units, transfer belt, toners, i also interchanged the laser units but is the same."
  • emilio pp
    emilio pp Aug 02, 2014
    This is a sample print
5 Related Answers
MSM
  • 165 Answers
SOURCE: Konica Minolta Bizhub c203 printer
where do u scan e mail or folder? if e mail your smtp server ip may have been deleted/changed if folder the path may have changed/deleted or password changed on the server/desktop
Posted on Apr 05, 2010
Bizhubman
Ben
  • 108 Answers
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
Posted on May 22, 2010
km284
  • 22 Answers
SOURCE: My bizhub c203 wont scan
please reinstall your connectivety with copier
Posted on Nov 25, 2010
Ty Schmidt
  • 118 Answers
SOURCE: how do i set my KonicaMinolta bizhub C203 to copy
set the copier on black then go to utility/counter, user settings then set current settings
Posted on Oct 16, 2011
Ty Schmidt
  • 118 Answers
SOURCE: how do i replace the
it is behind the right door but i doesnt need to be replaced you need a pico fuse about
$2 and it can be reset. if yoiu need more help in this and where the fuse is just ask
I have a kodak 4600 scanner that has an error " white patch not seen". i have tried to cleaning the imaging guides and calibration as wellthe scanner does not calibrate too please how can i resolve this.
Hello, I had a similar problem. The guides have a white stripe facing the camera (facing the inside of the scanner), the scanner uses this white stripe to define the image. If the guides are in place, and you turn the scanner off, you can see there is a black tape on one of the borders of the guide it is black on one side, and white on the other. You can take the guides off, and check if you can see the white stripe, sometimes this stripe has some scratches, or is not completely white. You can try placing a white piece of paper of the same size as the white stripe on top of the existing white stripe so that it serves the same purpose, if that does not work, you might need to take the black tape that has the white stripe on it, and try to replace it. The scanner needs that white stripe to be completely white. Hope it helps
Feb 26, 2014 | Kodak i1440 Pass-Through Scanner
Photo has stripes
If your Canon A85 shows similar/ like to below image then its ccd imager chip failure problem and ccd imager will be replaced.
Canon offers free of cost ccd imager replacement for A85 camera.
Click Canon CCD Imager Advisory for details.
Thanks.
Dec 20, 2009 | Canon PowerShot A85 Digital Camera
Printer prints stripes through images
your printer needs to be cleaned. Use the cleaning mode in windows printer HPOFFICEJET
Sep 18, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Camera overexposes on daylight and recorded images have hoizontal striping
I would take it off of automatic mode and adjust it manually.
The Samsung camera I have doesn't work very well in automatic mode under indoor conditions. It will work in automatic under outdoor conditions.
Hope that helps.
Mar 24, 2008 | Samsung Digimax L60 Digital Camera
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Horizontal stripes on images
may be the ink level in ur ink jet printer is low try and use genuine ink for ur printer . i also have the same problem . when i replaced with original ink it gets ok
Dec 03, 2007 | Canon BubbleJet i560 InkJet Printer
Image looks with white verital striped lines in playback mode
Mine had the same problem (except the stripes are horizontal).  I sent it to Canon and sure enough it is the CCD problem that many of these have.  The good news is that it is covered under a recall and Canon will fix it free, including the shipping.
Oct 18, 2007 | Canon PowerShot S1 IS Digital Camera
Underexposed, grainy images with a light stripe running down the center
Sounds like your shutter curtain is malfunctioning. Did you bump the curtain when u loaded film & bed it... Take a close look to see if it is binding. This is a very fragile area to monkey with & should be done by a qualified repairman
Jun 26, 2007 | Canon EOS Rebel K2 35mm SLR Camera
138 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
