Question about Lite On Computers & Internet
Why cant i find my lie on product onmycomutr
Lite on 24x dvd rw sata oem bulk package
5 Related Answers
Anonymous
  • 2961 Answers
SOURCE: my dell inspiron4150 notebook is my problem
Trying this should sort it, if not a drive fault:- Right click My computer>properties>device manager>hardware, then on CD/DVD devices line, click '+' sign then right click on your CD drive and click uninstal. Re-start your notebook and Windows should find it again and install drivers automatically. Try a cd in see if any better. Please rate solution
Posted on Nov 20, 2006
Anonymous
  • 56 Answers
SOURCE: problem reading blank disk
go to your burning software and look up disc info if it blank you will not be able to read it but it will show disc size space etc let me know how you get on
Brian
Posted on Jun 04, 2008
Anonymous
SOURCE: CD-RW/DVD-ROM wont write to 8x disks
My combo drive is unable to read any files in DVD. Please let me know what should be done.
Combo Drive SM-352F
Posted on Aug 15, 2008
Tom Torre
  • 279 Answers
SOURCE: lightscribe
They will have the lightscribe logo on them if they are compatible. They need to have a special ink embedded on the lable side.
Posted on Sep 19, 2009
anjana03
Roshan Rijal
  • 361 Answers
SOURCE: sata dvd rom cause the computer to crash, is it
on pata ,flate data cable use in long connerter . on sata cable we use thin and flatcable join in n small squire port. some bord have both type port we can use diffrent port in same time . but port should be good. i think there no chance to join different connecter joining. we look seriously. in any coonater we saw cuttin g shape or male female shape. power cable of smps which join in hdd/cd room may be lose when we join any part it can be short so connecting any cable before we do switch off or pullout powercable.
Posted on Nov 05, 2009
What SATA cables do I need to hook upDevice? Have factory installed into my CyberPower Desk top a LG Multi BlueRay/DVD/CD
SATA devices do not have jumpers to configure as a slave/master.
You connect each SATA device to separate SATA connector on the motherboard.
Nov 20, 2012 | LG GH24NS90 24x DVD RW DL SATA Drive Black
He can support lightsribe? tank
According to the following features:
•SATA Interface
•MAX. 24x DVD±R Write Speed
•SecurDisc™ Technology
•RoHS Compliant
•CD-R/RW, DVD-R/RW/RAM/ +R/RW +/-R DL Read and Write Compatible
•Windows 7 Compatible
Product broucher Link
It does not support light scribe but the GH24LS50 models do.
Thank you for using FixYa.
Hopefull this information helps.
Jul 28, 2011 | LG GH24NS50 DVDRAM Burner
Sir i am using acer 4736z i got problem with my dvd driver when i am inserting blank dvd for writing operation it shwos 0 bytes used free sapce 0 bytes not able to write data so what to do pls help me...
you have to make sure you are using the correct format for your drive i.e (+/-)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 8X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM, 4X BD-ROM, 4X BD-R, 2X BD-RE, 4X BD-ROM DL (double-layer), 4X BD-R DL (double-layer), 2X BD-RE DL (double-layer)
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM, 4X DVD+R DL (double-layer), 4X DVD-R DL (double-layer)
8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 24X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
Apr 09, 2011 | Acer Computers & Internet
I WANT A VISTA PRODUCT KEY FOR ACTIVATION?
id limewire that one mate i used to get my key codes like that on limewire select documents then type vista key gen ....
Jun 30, 2010 | 8x8 DVR-XD08 8x DVD RW Slim Drive - -...
Cant burn dvds with my lite on 5232k
This unit was not ever made to burn DVD only read and play them.
HERE is the source
May 03, 2010 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Is this good for a new gaming rig im gonna build motherboard: Gigabyte 790XTA-UD4 Motherboard cpu:AMD Phenom II X4 955 Black Edition Quad Core video card: XFX Radeon HD 5850 Black Edition...
I searched the internet and also from my experience can tell that this system is quite good. This system has all what is required by the latest gaming titles to run flawlessly.
If I would be pinpointing small issues then only would find that the hard drive needs to be at least 1 terabyte nothing else to complain.
In my opinion its quite a 'heavy' system and will sure give you an edge in modern multiplayer gaming over the internet where performance is the key to success.
Just a reminder that you should use 64 bit version of Windows on this system as a 32 bit system will not be able to use the 4GB RAM. A 64 bit system will better use the resources and you can upgrade to a higher amount if needed.
If you install a 32 bit OS it will show the total RAM as 2.5 GB and rest will be wasted. Windows 7 64 bit will be the best choice as it supports multithread, multicore CPUs and advanced graphics with DirectX 10/11.
In short I can say that this system is very much adequate for todays software/games and possibly future proof upto two years for extreme gaming. Also you can move to a better graphics card and more RAM when required. And be sure to use a adequately rated UPS/surge protector.
Mar 13, 2010 | Computers & Internet
I installed a philips-lite on blue ray player and need the drivers for it.
Hi friend,
You are not requried any drivers for it. it will work with out drivers...
Dec 20, 2009 | Philips LITE-ON 20x DVD RW Drive -...
Trying 2 burn cd and my computer is sayind cant
try reinstalling the burner then restart ur computer if the problem still ocurs then right click on my computer then manage then device manager then right click on ur system name (eg tom234) then scan for hardware changes and update ur drive, if the problem still ocurs then change the cable(sata or pata) then try.
Nov 04, 2009 | Lite On (SOHC-5232K) (SOHC-5232K-BULK)...
Computers & Internet Logo
Top Lite On Computers & Internet Experts
Vernon Taylor
ray gallant
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
