Question about Philips Smart 25TS54C 25" TV
Replacing Circuit Board Capacitor
I'm helping a friend trying to repair their tv. It's a Philips smart series 25ts54 c122. A part on the board has burned up (It's blue-green and assuming it's a capacitor) the position on the board it C506. Unfortunately it burned up enough I can't get any details from the piece. The TV started to smell funny and then smoke started coming out so they unplugged it. Later when they plugged it in, it wouldn't turn on but was making a quick ticking sound and then started smoking again. I removed the burn part and the TV now turns on and works without smoking. Obviously the parts there for a reason and would like to replace it but I don't know exactly what c506 is. Any help would be appreciated.
Posted by dismantle on
  • 2 more comments
  • dismantle Nov 09, 2007
    Terryfic,
    Are those parts from a circuit diagram listing that you have? Not that I don't trust you but I've been on too many sites recently that have people to claim to know what they're talking about when they don't. Suggestions are easy to rationalize but a specific part is either right or it's not and I don't to damage my friends TV with the wrong part. Also, do you know what particular function that part of the board controlls since it made noises and smoked when it was plugged in without being turned on (wouldn't power up with the bad part) - but when totally removed from the board the TV turned on, pictures OK, has sound, and seems to work OK. Just wondering.
  • dismantle Nov 20, 2007
    OK, I replaced the capacitor and now the TV powers up and the sound is fine but all I get is a horizontal line about the middle of the screen. What happened? It was working OK without the capacitor at all and now I've tried it with and without the capacitor and all I get is the horizontal thin line.
  • dismantle Nov 21, 2007
    I'll have to keep looking for ic501. I found IC500 by the video input area and they were loose so I resoldered them but no luck. I'll check for IC501
  • dismantle Nov 28, 2007
    I checked D409 by the flyback and D410 (half the board away from the flyback). Both are registering fine provided I can assume an accurate reading while they're still on the board. Using a diode tester I get no reading one way and around 530-550mv drop the other way so, providing they aren't getting feedback from another path on the board, I think they're both OK. Any other ideas?
Vista Electronics
    Genius:
  • 1,694 Answers
820pf / 2KV capacitor Philips # 483512257004 Andrews
Or # 13-821U HB Electronics .......T.
Posted on Nov 08, 2007
  • 2 more comments
  • Vista Electronics Nov 09, 2007
    I take care of some hotel / motel repairs that have dozens of
    the same model...........................
    Part function is HV adjust / shaping of picture = exact size.....
    Also may relate to x-ray radiation parameters........T.
  • Vista Electronics Nov 20, 2007
    Solder connects on vertical output IC501.................
  • Vista Electronics Nov 21, 2007
    Sorry, should be IC500.....FYI = Whenever any circuit board is
    serviced, a certain amount of movement occurs. At times, the
    result is a secondary issue completely unrelated to the original
    problem......Since soldering the vertical output IC did not help,
    your next check will be the B+ source(s) to run the vertical IC.
    Locate D409 / D410 ? diodes next to flyback xformer = check
    w/ ohmmeter = shorted ? Overheated-looking? = replace BOTH W/ part #483513037052 AND replace IC w/ part # 483520988531
    all three at the SAME TIME !..................T.
  • Vista Electronics Nov 28, 2007
    With diagram in hand, check all voltages at pins of vertical o/p
    IC......work back to power supply....or, I quote myself "check the
    B+ sources to run the IC"......next = try subbing the IC.....next =
    take it to a shop...........................T..........OUT.
2 Related Answers
trintek
Trinity Sabre
  • 111 Answers
SOURCE: Philips 25ts54c122 capacitor C506 Trouble
check the horizontal output transistor, it may have gone belly up. good news is a replacement is only 6-7 bucks.
Posted on Nov 20, 2007
Anonymous
SOURCE: Philips model HD2528-C122 value for capacitor C506?
I could still make out 68 over 2kv on the burnt capacitor. Replaced with a 680 pf 2kv that I bought at a local TV repair shop. works great.
Posted on May 29, 2008
PHILIPS MAGNAVOX MODEL 19PR15 C122 HAS NO SOUND
Check speaker. Audio circuit. Mute signal
Apr 01, 2010 | Televison & Video
Stuck dvd and no power
I fixed this problem in my DVP642 by replacing a capacitor on the main power board where the power chord hooks in. Take the top cover off (after unplugging player). You'll be able to locate the bad capacitor on the circuit board located on the very right. Look for location marked c316 on the circuit board. A bad capacitor will be bulged up on top. The capacitor you're looking for will be a black barrel shape with an aluminum top, this aluminum top will be bulged up or leaking on the circuit board. Replace this capacitor by desoldering the two leads into the board and replacing with an identical part you can pick up at Radio Shack for a couple dollars. My repair for this identical problem was a success. The blinking light is the tip off for this particular problem on these Phillips models.
Oct 08, 2009 | Philips DVP642 DVD Player
I have a blinking red light and it wont cut on
Aug 16, 2009 | Philips DVP642 DVD Player
May 27, 2008 | Televison & Video
Tv won't power on red LED blinks 4 times
HI,
Was there any recent power interruption or a thunderstorm recently in your area?
Mar 11, 2008 | Philips Smart 25TS54C 25" TV
Philips magnavox model 25ts54 c122.
hi there, you do have a power supply section problem, check the bleeder resistor which is 100K ohms or up. do some test. ty
Dec 24, 2007 | Philips Magnavox 27MS343S 27" TV
Tv won't stay on!
Check C506 = high failure item # 483512247584 680pf / 2kv
Dec 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won't stay on!
Replace C506.......680PF / 2KV..........................+ solder any
and all bad connects......+ replace 47mf/25v cap in horiz drive circuit................T.
Nov 26, 2007 | Philips Smart 25TS54C 25" TV
Nov 20, 2007 | Philips Smart 25TS54C 25" TV
Televison & Video Logo
891 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
