Question about Technics Audio Players & Recorders
How do I fix the speed of my Technics SL-6 Turntable?
My turn table seems to be fixed to the fast playing speed. It has an auto, slow, and fast button but nothing changes when switching the speed. Is there a way to fix this? Am I missing something? Thank you.
5 Related Answers
fire sine
Keith Seekwhensir
  • 382 Answers
SOURCE: Technics 1200 MK2 displaying irregular speed to include dragging and slowing
It sounds like the pitch slider needs to be replaced...
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Cover insured UPS charges both ways and you will get sorted.
Posted on Oct 28, 2007
Anonymous
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
Posted on May 21, 2008
Anonymous
  • 515 Answers
SOURCE: Technics SL-1200MK2 Turntable i need to replace the on off switch on a mk2 technics 1200 any
The part is located HERE - but you will have to take apart your turntable from the bottom in order to replace it. It's not very hard, but if your not mechanically inclined, I would not suggest doing it, as you could cause more damage.
- OPTiC
The 1200s Expert
www.1200s.com
Posted on Sep 08, 2008
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: help for technics 1200 MK2 and 1210 Speed is too fast
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Posted on Apr 04, 2009
Anonymous
SOURCE: Technics SL-5 Turntable will not turn.
now iam using the technics sl-5 turntable.it is tonearm damaged.
replacement tonearm are available? or pl inform tonearm model number
Posted on May 12, 2010
Got a panasonic compact audio system model # SG-HM09A the turntable plays the record fast
there should be a small switch on the inside of the turn table that allows you to switch from 45 (what i think your listening to) to the normal speed which i think is 33
Jan 25, 2013 | Panasonic Audio Players & Recorders
Slow sound on window xp
Change playback speed in Windows Media Player
Begin playing a file.
Click the arrow below the Now Playing tab, point to Enhancements, and then click Play Speed Settings.
Move the Play Speed slider to the speed at which you want to play the content, or click the Slow, Normal, or Fast link.
To select speeds between the labeled play speeds, in the Enhancements pane, clear the Snap slider to common speeds check box.
To hide the settings, click the Close button in the Enhancements pane.
hope this helps
Jul 30, 2012 | C-Media Electronics Computers & Internet
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Feb 15, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
The turn table is going round but its playing the record to fast the speed seems wrong
Hello!
are you sure, that your speed selector is on 33.3rpm, not 45?
assume, it's in correct speed settings. do you know, that across the ocean power grid AC frequency is 50hz, in US it's 60hz. Means: ac motor will spin faster, than it should. If you bought this unit abroad, that's where is your problem at. some expensive units have 50/60hz pulleys switch, some not. Especially, if it's DC or direct drive motor. Check your owner's manual for specifications. May be you find an answer. If not, there is a problem with motor's regulator, which is built in(DC motor). Turntable is a belt driven. If you won't find 50/60hz adjustments, take it to repair shop.
Good luck,
Alex.
Jan 11, 2012 | Aiwa PX-E860 Turntable
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
I have a Sherwood PD - 913 R and the pitch seems to be spinning out of sync which makes the RPM"s not right for 33 or 45 speeds, any help on what could be the cause is appreciated. There is a pitch...
The turntable motor might be the problem, if the grease is old it becomes hard causing the turntable to run slow, by your description we can rule that out since you indicate it runs to fast. therefore it is the voltage that powers the motor with a regulator "keeps voltage constant" or the motor itself will be the problem. The pitch control allows a small change in speed when required.
Dec 30, 2010 | Audio Players & Recorders
VIDEO STARTED PLAYING BACK ONLY IN HIGH SPEED W/O VOLUME,,,,,,,CHANGED SPEED OUT OF NOWHERE.....PLZ HELP! I'M USING CANON G9
I EASILY FIX'D THIS PROBLEM & FOUND OUT I CAN DO SOOOOO MUCH WITH SHOOTING VIDEO'S! I DID A GOOGLE SEARCH & CAME ACROSS THIS ADVICE.......TURN THE TOP DIAL ONTO VIDEO ON TOP OF CAMERA. THEN TURN DIAL ON RIGHT SIDE & YOU WILL SEE DIFFERENT SCREENS SUCH AS BLK & WHITE, VIVID COLORS, FAST OR SLOW SPEED; I TURNED MINE TO AUTO & PRESSED FUNC BUTTON IN CENTER OF WHEEL & I WAS BACK TO SHOOTING IN NO TIME........HOPE THIS HELPS!!
Jun 20, 2009 | Canon PowerShot G9 Digital Camera
While wathing movie by acer 3260 laptop video & audio slow
Hello sanjeev_vada,
This procedure is from the windows media player help file.I hope it's useful:
*To play content at variable speeds*
You can change the speed at which content plays in the Player. For example, you can slow down the playback speed if you are taking notes while watching a training video, or you can speed up the slow sections of a presentation.
•Begin playing a file.
•Click the arrow below the Now Playing tab, point to Enhancements, and then click Play Speed Settings.
•Move the Play Speed slider to the speed at which you want to play the content, or click the Slow, Normal, or Fast link.
•To select speeds between the labeled play speeds, in the Enhancements pane, clear the Snap slider to common speeds check box.
•To hide the settings, click the Close button in the Enhancements pane.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jan 05, 2009 | Microsoft Windows Media Player
Sound skips in and out at the beginning only
Try updating/re-installing your audio drivers from the laptop website, or from manufaqcturer's website. Also, update your Chipset drivers.
Hope that helps
Tim
Dec 19, 2008 | Computers & Internet
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
329 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
