You're not officially supported.
Install the app. Input your cell phone number in the app on the ipad. When you get the activation code on the cell phone input it to viber on the ipad and it should work over Wifi from there. Note that anyone who uses viber to try and reach your cell phone is going to get your ipad instead.
SOURCE: Apple Ipad won't charge
IThe iPad needs more power than the average USB device. It doesn't run and charge at the same time on a regular USB port. If it doesn't charge with the original charger though, you have a hardware issue. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
SOURCE: how to empty trash in
In general, an iPad doesn't have a trash at all. Since you don't have access to the file system, files cannot be user-modified or deleted, so a trash is not necessary. Further, apps will generaly take care of their own cache and data usage, so user interventions doesn't generally occur. If you are talking about mail, try using the usual delete functions while navigating the Trash folder and you should permanently delete the message.
Hope this helps,
Alistair
SOURCE: I purchased an ipad in
The device that you bought is not an 'iPad'. It's actually a 'tablet'. iPad is the tablet manufactured by Apple. Now for your tablet... do a manual search for the product on the company's website. Anyways, Android is very intuitive and easy to work.. so just play around with the device for some days and you will find out how things work. If you still have some issues, post it here on fixya.
SOURCE: transfere photo from laptop to apple ipad
To transfer photo from laptop to iPad, follow this steps.
1. In the iPad management screen, click the "Photos" tab at the top.
2. Check the "Sync Photos" box at the top.
3. From the drop-down menu next to that, select the program or folder that contains your photo library.
4. Once all your settings are correct, click the "Apply" button at the bottom right corner of the iTunes window to sync again and add photos to your iPad.
5. Photos will consume space on your iPad, so keep that in mind as you select between syncing all photos and individual albums and videos.
