Charger changes from flashing amber to green light. but the phone does not switch on.
SOURCE: blackberry curve won't turn on...
Wipe it to start over. Sometimes when you change or add something like a THEME or a download it HOSES the BB completely. So delete what was on there and don't download a theme or any other wacky add-on.
To Sanitize or Clear out all the information in a Blackberry Device
Scroll to select the OPTIONS icon and press [Trackwheel] to select.
Scroll to select SECURITY and press [Trackwheel] to select.
On some units you may have to select GENERAL SETTINGS before getting the next menu.
Press [Trackwheel] again to access the Menu screen for the security.
Scroll to select the WIPE HANDHELD and press [Trackwheel] to select.
Scroll UP to select CONTINUE and press [Trackwheel] to select.
Type blackberry on keyboard to confirm the action press <-| key.
System responds with ERASING INFORMATION.
SOURCE: my new battery to my blackberry will not charge
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues, like charging issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
SOURCE: Trackpad on Blackberry Curve 8520 has stopped
i had the same prob with my bb 8520 .. i have got this info 4rm a site n it waz a video telling u how to remove ur trackpad ... i have removed my trackpad according to the video n cleaned the sides n the trackpad .. n connected it carefully ..Now it works Perfectly ! its not hard but its risky .. n now have a look at the video ' http://www.youtube.com/watch?v=-HgLXRgedvI ' believe me it really works :D !
Sounds like your trackpad needs replacement. The part is available on major auction websites for around $10. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
SOURCE: locked out of my blackberry curve 8520 smartphone
Did you forget your own password? Don't worry you can use your PUK code to unlock blackberry curve 8520 password, just type any password until your phone asking you to enter puk code. PUK code can you found from your sim card bundle if you don't have it just call your service provider, they will give it to you. After you put that puk code your blackberry unlocked from old password.
