None. Have no manuals.
SOURCE: hookups
You can download the manual from the link below: http://63.148.251.135/redirect_service.cfm?type=own_manuals&file=TXSV414PROom.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Onkyo TX-V940
the protection circuit has failed. I sometimes find
that the contacts in the protection relays will be slightly burned and
that will make the sound cut out randomly. Turning the volume control
up higher than normal will make the open circuit of the burned relay
contacts work again and so will the sound.
in most cases replacing the protection relays will fix the problem. You
may want to first verifiy that the relays are defective by measuring
the contact resistance when the problem shows up.
Goodluck,
Don't forget to rate me as fixya..
SOURCE: No receiver display lights
Hi ripper
The unit has a built in display dimmer, with a button to control the level of brightness from the display both on the remote, and the front panel.Try this
regards
Graeme
SOURCE: Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
