Question about KitchenAid Refrigerators
Hook up icemaker to water source - KitchenAid Refrigerators
Posted by Wendy Mauro on
jun93
    New Friend:
    Problem Solver:
  • 16 Answers
If you are doing a new installation, the icemaker should either come with an installation kit or recommend one. The kit comes with all of the hardware needed to basically "tap" into your existing cold water line. Your refrigerator is already prepped for the icemaker so it's just a simple bolt in operation.
Posted on Jul 28, 2014
Can I remove the ice maker
They are easy to remove. Just remove the screws and unhook the connector and tuck it away behind the back plate.Many years ago there was an icemaker that had the defrost timer as part of the icemaker. If you took it out then the refrigerator wouldn't run. these are mostly long gone. You should be OK to take it out.
Aug 02, 2014 | Whirlpool Refrigerators
I have an Amana Side by Side Refrigerator with an icemaker and water dispenser. I don't have a water line to hook up to the refrigerator. Is there an on/off switch for the icemaker?
There should be a stop control near the icemaker where it collects ice in the tray. It should be an L-shaped lever. move it to the stop position.
Oct 02, 2012 | Amana Refrigerators
Icemaker stopped working
You will have to determine whether the problem is due to no water getting to the icemaker or a control problem in the icemaker unit.
There is a water valve near the bottom of the refrigerator where water from the outside source enters the refrigerator. This valve sends water to the icemaker (and probably the water dispenser) when the refrigerator controls call for water. These valves can malfunction, and the water lines can get blocked.
The other possibility is that something inside the icemaker controls has malfunctioned, and it is not calling for water.
Oct 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Icemaker not signalling for water.
cheek the condenser fan.if its opration is not correct.
May 23, 2009 | Whirlpool GD2SHGX Refrigerator
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
Icemaker
Yeah sounds like the inlet valve needs replacement.
Dec 12, 2007 | Hotpoint HSS25GFP Side by Side...
Ice maker not getting water in the line
The only other component stopping the valve from putting water into your icemaker is the icemaker itself. Replace your icemaker and you should solve your problem.
Nov 14, 2007 | Amana ARS2464B Side by Side Refrigerator
Refrigerators Logo
44 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
