Cannot find any replacement wheels.
SOURCE: Dirt Devil Reaction Vacuum belt replacement
The manual is confusing - I had the same problem. Make sure you put the belt around the smaller motor axle, not the lever arm attached to the on/off foot switch. It's a bit counter-intuitive, but that was my problem with this. Jeff
SOURCE: our dirt devil vacuum is blowing out air instead
my dirt devil is blowing out air instead of sucking up.Tried new bag.any other solution to fix
I've found that the actual wheel part with the one inch hub is usually not at fault. The case of the vacuum is the place that the wheel attaches to, simply by pressing it into a hub hole. Appears this poor design generates a lot of friction that wears out the case rather than the wheel.
