Question about Proscan Televison & Video
How do I program universal RCA remote to my Proscan tv?
I bought my Proscan tv from K-Mart and since it was the showroom display it did not have a remote. I have a RCA universal remote and want to use it.
Greg Bernett
  • 2,989 Answers
Posted on Jul 28, 2014
5 Related Answers
Anonymous
  • 124 Answers
SOURCE: code numbers to set up iLo tv
Remote code for ilo: 1286
Posted on Apr 08, 2008
Anonymous
  • 21 Answers
SOURCE: Programing Code for RCA Universal Remote Control
It does not have any code.
Posted on Oct 22, 2008
Anonymous
  • 814 Answers
SOURCE: proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Posted on May 21, 2009
Anonymous
SOURCE: Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Posted on Jul 22, 2009
Anonymous
SOURCE: cant program Vizio TV using RCA universal remote RCR312W
can i program an rca remote to a vizio tv?
Posted on Dec 01, 2010
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
RCA L32HD31R/Dish Network Remote Code Problem
The word from RCA technical support is that the remote for the L32HD31R operates on a different frequency and there is currently NO universal remote on the market that will work with the set. They say that they have plans to market a universal remote and that they are working with other manufactuers of remotes but there is no resolution or time frame available. In short, you will have to use two remotes and keep checking the RCA website for a breakthrough.
I'm not sure that I would have bought the TV if I'd known.
Jun 26, 2009 | RCA L32HD31 32 in. LCD HDTV
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
No remote
If the TV is in fact an RCA (Proscan is an RCA brand), you can buy an RCA universal replacement remote and it will work the TV right out of the package. Depending on the TV model, some features may not be accessible with a universal remote, though. The original TV remotes sometimes have function buttons that the universals don't. But all basic functions would be available.
Jan 02, 2009 | Proscan PS35130 TV
32" proscan dual hd tv can't get universal or direct tv remote to work what now
Get a universal from big box and program. If you can find a rca remote, it should be programmed already.
Craig www.classtorations.com
Jun 08, 2008 | Proscan PS32500 32" TV
Manual for Proscan 32" LCD TV
http://www.oncorpus.com/down/down.htm
This is the site for the Proscan manufacturer. Should be able to get answers and/or tech support.
Jan 18, 2008 | Proscan 32LA30Q Television
Lost remote and rca universal remote no can be programed
I used the remote control code of "69" for Thompson which makes GE & RCA according to another post. This worked to program the remote of my GO Video DVD-VCR for the TV
Dec 29, 2007 | Proscan PS27113 TV
Televison & Video Logo
264 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
