Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
SOURCE: loud bang during dryer rotation
not nkowing what brand, I would guess its a maytag or one of their brands. It sounds like a screw that mounts one of the paddles inside the drum has backed out and is now poking out the out side of the drum hitting the cabnet as it goes around. Un plug it , pop the top open , rotate the drum clock wise by hand slowly to see if a screw is standing up on drum.
If its a whirpool dryer with the lint filter inside the door, the top cabnet is dented down, hitting the drum.
someone sat on the top, bent it down.
