Again!!!! Unplug machine X 15 minutes. Then fill with water. Then plug back in! If still lit, you have a water scale (mineral build up) issue that needs cleaning according to owners manual
these humidifiers are total junk. The sensors are cheap and get stuck or broken so easily. for your problem tho, you can either find the sensor by taking off the cover and use your hands to break free any stuff causing it to get stuck or you can drill a hole in the water tank and insert some fish tank tubing and let the water drain out as it collects.
I agree with Mike Kolbay's earlier very complete answer. The water intake to the pump is quite narrow, and clogs easily with accumulated lint and bacterial muck. While the covers are off the machine, thoroughly clean the drip tray and all the water passages. A piece of crud the size of your smallest fingernail can cause water to overflow onto the floor, rather than going into the tank.
Hi, There are many reasons for a dehumidifier to not work or collect water. Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
If you have the fan icon selected, it is supposed to run continuously. If you use the mode button (not the fan button) to change to relative humidity (the water drop icon), the fan should only run with the dehumidifier.
This tube is likely related to the water pump out feature that these have. They have a pinch clamp on connections, perhaps your clamp is loose or misaligned.
