Question about Jacuzzi Home
Why is my jacuzzi toilet not flushing properly
The cistern is filling verily slowly and squirting out the sides
Allan
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
First try yourself for checking internal part where some particle stuck inside the flush or check the flush for how much water coming from the pipe if not found properly then i suggest A-general plumbers for best services they handle this type of issue easily.
http://www.a-general.com
Posted on Aug 04, 2014
5 Related Answers
Anonymous
  • 239 Answers
SOURCE: Toilet fills up slowly
buy a universal fill valve and replace it
Posted on Jan 03, 2009
Anonymous
  • 16 Answers
SOURCE: toilet cistern doesn't fill up
it sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Posted on May 03, 2009
jpintore
  • 129 Answers
SOURCE: i needs new valves for my dual flush, close
No I'm sorry they do not. You might try plumbing supply house in your area.
Posted on Sep 26, 2009
Anonymous
  • 86 Answers
SOURCE: toilet doesn't flush properly
What is VERY much possible is not the sewer pipe, but an obstruction in the toilet itself.
Remove the toilet turn it upside down (on soft grass or grown) and jostle it up and down or rap lightly with a rubber mallet.
There can be surprisingly large things like a stick of deodorant, toys, or other objects that accidentally (or if children are involved) intentionally flushed.
It definitely is the toilet bowl itself. EVEN if you run a snake through the toilet bowl from the underside while you have it outside. Sometimes the object gets lodged in there good. But it is the toilet and NOT any of your pipes.
Posted on Mar 20, 2010
co7196
Ned C Cook
  • 3433 Answers
SOURCE: cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
Posted on May 26, 2010
Dual flush toilet fills slowly. The fill valve is pushing water cistern seems ok. The fill hose shoots water down overflow tube this is the design. If hose placed tank it fills no problem.
check /replace the small rubber washer at the end of the fill tube as they tend to grow with age and reduce the flow of water past the inlet
Oct 11, 2016 | Home
How to mend a running gural vitrifiye toilet cistern
With lid removed, look down into it and remove and replace the black rubber thing in the center. This is the flush valve and is worn to the point where is no longer provides a tight seal allowing water to pass and run into bowl. Also, could be something underneath it not allowing it to seat properly.
Aug 26, 2014 | Home
What is causing my toilet cistern to fill very slow?
The fill valve (operated by the float) may be clogged with sand or debris from inside the pipe. It's generally easier to replace a fill valve than it is to take it apart & clean it.
Jul 31, 2014 | Caroma 270W-RF Reflection Round Front...
Why my uberhaus dual flush toilet does not flush properly
Perhaps it is taking a long time to fill the cistern, take top off and see if it's filling after flushing, if it's slow and pressure is ok it is likely to need a new diaphragm in the filling valve.
May 12, 2014 | Home
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
I have a Jacuzzi Perfecta commode. It has worked fine until all of a sudden, the tank began filling very slowly. It now takes from 5 to 7 minutes for the tank to fill. I've replaced the flush valve,...
keep going...i mean disconnect the supply line from the fill valve, hold the line into a bowl/bucket and slowly turn the water on. is there pressure? sorry for delayed response if you text me back i will try to answer expeditiously:)
Jul 26, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
We have a Jacuzzi X532 toilet. Can't get the water to stop running into the bowl, causing excess water usuage and stains intoilet bowl. This started about two weeks ago. Have this toilet approx. 3-4...
I am not familiar with the model of toilet that you have, but many toilets suffer the same problem. It is usually due to the toilet cistern over-filling, as the water running into the bowl is the safety-overflow mechanism. The overfilling can be for a few reasons. The most common is that the fill valve is being held open, either due to mal-adjustment, or due to it being postioned slightly wrongly so that it hits either the side of the cistern or another part of the mechanism and can't close off properly. If you lift off the top of the cistern and watch what happens when the flush goes, you might be able to spot what is preventing the valve from shutting off entirely, and solve it. Hope this helps! :)
Jul 19, 2010 | Jacuzzi Home
I have a push button flush and water is filling up toilet cistern more slowly than usual after the flush has been used - is there a problem with this? I don't know what brand it is but probably comes from...
A couple of things you should check. Is valve on water supply line fully opened? Does 'flapper' or ball seal the discharge tube completely? Is fill tube functioning properly? One or more of these is causing the problem
Jun 24, 2010 | Home
Home Logo
300 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
