Question about Pitney Bowes Compatible 9700 / 9720 Toner 805-7
Pitney bowes manual
ChANGE ACCESSCODDE
Nike Merritt
  • 149 Answers
Use ****1 until I can find directions
Posted on Jul 30, 2014
5 Related Answers
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: need to set a pitney bowes 9820 to print a fax confirmation
Function
74
set
12
set
set
stop.
Posted on Nov 20, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: Pitney Bowes 1530 Fax Machine
On top of the operating panel is a small removeable tab with a bump on top. (not the Blue ones) Pull it out of the machine This is the battery holder.
The battery is a CR 2032. Most electronic stores sell them.
Posted on Jan 31, 2009
Nike Merritt
  • 149 Answers
SOURCE: Pitney Bowes 8000, when I go to Copy it prints BLACK
your thermal print head is bad. This is a very old machine and I do not know where you can get parts. This machine is no longer supported by field repair
Posted on Oct 10, 2009
Nike Merritt
  • 149 Answers
SOURCE: 9720 Pitney Bowes Fax - access code has mysteriously been placed
Function 9, access code is 9720, press yes, press no until you get to set access code? press yes, delete code, press yes, press stop. I don't think this manual in online any more, but you can go to www.oceusa.com, go to drivers and support, and look for 9820 or 9800 series. The programming instructions are the same as this model
Posted on Dec 24, 2009
Nike Merritt
  • 149 Answers
SOURCE: pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Instruction manual for pitney bowes copier AD20
I have this manual on my computer. If you send an email to [email protected] I will send the manual to you right away. Please put PITNEY 9920 as the subject line. I hope that this will help you out. Lawrence Brown
Oct 21, 2011 | Pitney Bowes C180 Copier
Pitney Bowes Manual for AD20
Oct 21, 2011 | Pitney Bowes 9920 Plain Paper Fax
I need a Pitney Bowes DM200L postage meter repair manual
I found someone with the same problem at the following website.
http://forums.pb.com/t5/Equipment-Hardware-and-Supplies/DM100i-WASTE-INK-TANK-FULL-NEEDS-REPLACEMENT-MESSAGE/m-p/2589
Dec 21, 2009 | Office Equipment & Supplies
Jan 31, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 1225 letter opener
I don't know if Pitney Bowes is still servicing those anymore but you can find out on their website:
www.pb.com
Select the customer support section.
Nov 21, 2008 | Office Equipment & Supplies
Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Jul 10, 2008 | Pitney Bowes C180 Copier
Pitney Bowes Fax Function Question
I have a 9920 manual,could be the same.Try the following but if you get different displays don't change anything.Press function,should read FUNCTION SELECT , ENTER FUNCTION # .Enter 8, scroll to AUTO REDUCTION.(use COM STAT or HELP keys to scroll)Change to NO.Press stop to return to normal mode.If this procedure is not exactly the same for your model,then just search through the function settings and find AUTO REDUCTION and set to no.
Mar 05, 2008 | Office Equipment & Supplies
Pitney Bowes Compatible 9700 / 9720 Toner 805-7 Logo
150 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
