Car wont start even though it has power in car. turn key every thing is on but car does nothing
Disconnect the battery and clean both terminals. Wait about 10 minutes before re-connecting battery terminals. That will reset your car's computer. Should start if there is enough juice in the battery. If you hear a clicking sound when you turn on the engine it means your battery is too low to turn the engine and probably means it's time for a new battery. Get someone to give you a boost and it should start fine. Your battery is probably original equipment and more than 8 years old. Thats about maximum life expectancy for a battery.
SOURCE: how do you control the dashboard lights in a 2006 cadillac cts
How can I increase lighting on the dash control panel in a 2004 Cadillac CTS
SOURCE: My key is stuck in my 2003 CTS and the TC light came on
hi there i think the problem is blunt residue caused by swisher sweets home boy
SOURCE: 88 cadillac deville, ac blower fan wont shut off,
Ralph,
Most common cause of this is the blower fan (proper name for the fan you refer to) continuing to run is a shorted out Electronic Climate Control Module. This solid state device replaces the older style fan speed resistor block (at about 4 times the price) This unit is found on the top of the HVAC box under the hood. (HVAC means heating, ventilation and air conditioning) The HVAC box is found on the passenger side of the firewall. Look behind the A/C's accumulator. It will have an electrical wiring plug on top of it. It will be fastened to the HVAC box with a few 7mm hex head screws. Very easy to change.
FYI, do yourself a favor and replace the blower fan motor at the same time. The Electronic Climate Control Module usually fails because the motor is drawing to many amps of current. This is because it's bushings are worn out or the brushes are worn out.
This is very common on Cadillacs and Buicks.
Charlie
PS Not sure why car won't start. Either you drained the battery or blew a fuse which controls starting the engine. Need more info regarding the "no start" condition.
SOURCE: cadillac 2004 cts, wont start
i had a 2003 ctc that did the same thing, it wouldn't start or would make a clicking sound and about 1 mth after the problem started aND mechanics could not find a problem my car caught on fire and burned completely from something under the right side of the hood. i had just parked the car and got out, it happened really fast. the fire chief said the cause was unknown????
now i have a 2004 cts and i'm having the same problem!!!!!!!!!!!!!!! has anyone else had this happen???? please be cautious if your cts is doing this, during the fire my doors locked and had to be pried into by fire chief.
SOURCE: 2003 cadillac cts v6 3.2 liter. white smoke
u have a leak in the heater core the oily smell and mist is anti freeze sounds like a small leak because usually u would have a wet floor if it was large -two choices check and repair as necessary the core or can use an additive with a stop leak they usually work well on small leaks
