Car Audio & Video Logo
A
Anonymous Posted on Jul 27, 2014
I had my boston g5 hooked up to a 100 watt amp and it just stoped woking one day
I had my Boston g5 hooked up to a 100 Watt amp and it just quit working one day.
Anthony Carman
Level 2:
Habit-Forming:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 126 Answers
  • Posted on Nov 30, 2014
Anthony Carman
Expert
Level 2:
Habit-Forming:
Cheetah:
Answers
126
Questions
0
Helped
38283
Points
182
Check with a. Meter if no impedance it's blown.
1 Related Answer
Anonymous
  • 11 Answers
  • Posted on Nov 07, 2009
SOURCE: Subs stoped
So...disconnect the spkr wires and put a known good AA battery across.
  • If the spkr pops, it's likely OK...if not, spkr is defective/toast. Best if you have VMeter - check for 2 to 8 ohms resistance.
  • You have used a test light to check powers - that includes the 'trigger' control from deck. Does the 'on' light on the amp come on?
  • High wattage means high current. Make sure your ground is to a clean unpainted metal surface. Plastic will not do !
  • Mandatory fuse at clean battery post using '0' - '4' gauge power wire, otherwise undercurrent will shut down amp.
My Boston Acoustics ASW 650 just turned off yesterday and wont turn back on. What could be wrong?
Check for the wires connections on all the terminals.
Else it is a minor problem due to power fluctuations.
Take it to a nearby technician.
How do I hook up my Boston Acoustics to my Mac Mini
Depends on what wattage is of the BAs. You will have to preamp the mini and then run to an amp and then to the speaker.
1helpful
Boston Acoustics CS26 Speakers sound cuts out for over a second at higher volumes tested using two different amplifiers same problem. Does not seem to be related to amp distortion:clipping protectio
It sounds like the speaker cones(if that is what they have) get hung up against the back of the case. No vibration=no sound. Check to see that there is no hum adding to the pressure on the speakers. Check to see that the speakers are hooked to the correct impedence output of the amplifier. Also, wire length affects impedence and shortening the wires might help.
On the connection for my Boston Vr2 Floor Speakers there are 4 connections which are connected vertically with a brass plate which is approx 1/2 " wide. I have lost one and the speaker does not seem
You can use a piece of speaker wire to replace the missing bar. those speakers are designed to be used with the bars in place for normal use. they can be removed if you are bi-amp/bi-wireing them.
3helpful
2answers
Zd 3 diode value on boston acoustic soundware xs 5.1 subwoofer
Replaced the ZD3 on the Boston Acoustics Soundware xs 5.1 subwoofer with a 18 Volt-1 Watt Zener part number 1n4746a. and works like brand new.
I have a kenwood excelon (794, I believe) with 6 pre-amp outs. I'm currently running a boston acoustics gt2-125 amp powering 1 alpine swr-t12 shallow mount, type-r sub (12"). I have 2 alpine...
This answer will require a very detailed technical solution, therefore I recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information proves beneficial.
2answers
Subs stoped
Any sub can be blown in 30sec if given bad clipped power, so just measure them with a multimeter and see if the coils still have resistance. Throw away the test light and only use a multimeter.
Top Boston Acoustics Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Boston Acoustics Car Audio and Video Expert? Answer questions, earn points and help others
