Question about Janome D'cor Excel Pro 5124 Mechanical Sewing Machine
Janome twin needle
Can I use twin needles on Janome Excel Pro 5124?
Debbi's Sewing Machine Repair
  • Janome Master
  • 7,365 Answers
You should be able too, I sent you a link for a manual, the information should be in it.
Posted on Jul 28, 2014
5 Related Answers
Mimito7
Kelley Buchanan
  • 130 Answers
SOURCE: howto thread a twin needle on Janome 6019
Hi there. If you have an acessory kit with your machine, there should be a plain spindle with a smaller bottom on it. There should also be a small hole on the top or back of your machine where your thread goes.. And yes you can thread both strands of thread thru the same areas till the needle.
Posted on Apr 28, 2009
ndirons
SOURCE: Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Posted on May 02, 2009
Eva Hack
  • 25 Answers
SOURCE: Using twin needle with Janome dc3050
you can just use the straight stitch.If you want to use a fancy stitch you have to be careful that the throw, as I call it is not too wide as you could break the needles and put the timing out. Also use a longer stitch than normal.Also use the stretch twin needle.
Posted on Feb 11, 2010
paj42
  • 1116 Answers
SOURCE: Janome ENX24.needle tension will not adjust.
Set the tension to zero and floss it with a piece of fabric or twill tape.
Re-set the tension to 4, or where you would normally set it for this machne.
Thread the machine with the presser foot up, this opens the tension contol to allow the thread to enter.
If you are still having a problem, the machine needs to go in for service.
Posted on Mar 05, 2010
Anonymous
  • 6 Answers
SOURCE: Can I use a twin needle on my Janome MW3018?
Twin needles can be used on any machine. Just make sure you use the correct presser foot......one that allows both needles to work without hitting the foot. Also.........you cannot zig-zag or use any other fancy stitch with a twin needle.......it is strictly for straight sewing. You have to use 2 spools of thread .....thread your machine with both threads as if they were one thread but separate the threads when you get to the needle. There is no change to the bobbin. Happy sewing. I can't be bothered to go to all this trouble so I just sew 2 rows to get the same look. Ofcourse you have to be very good at sewing perfectly straight seams doing it this way. Try both methods on a scrap and see which method you prefer.
Posted on Dec 21, 2010
How do I thread to use twin needles on Janome Excel Pro 5124?
here is a link for a manual, the information should be in it about the twin needles Instruction Manual Janome 5124
Jul 27, 2014 | Janome D'cor Excel Pro 5124 Mechanical...
Instruction manual for Janome Excel Pro 5124
did you ever get a answer to the question you asked?
Jan 25, 2012 | Janome D'cor Excel Pro 5124 Mechanical...
Lost my sewing instruction manual when moving house. Can't remember stitch patterns adjustments. Need a new sewing manual for my Janome Decor Excel 11 5024 Thank you
Hi
You can download some partial manuals from the Janome site.
This is for the Janome D'cor Excel Pro 5124:
http://content.janome.com/documents/File/ManualFile/DecorExcelPro5124.pdf
Which should be similar to the ohter model number you mention.
Hope this helps!
Nov 16, 2010 | Janome D'cor Excel Pro 5124 Mechanical...
Janome D'cor Excel Pro 5124 Mechanical Sewing Machine Logo
189 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
