SOURCE: Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
SOURCE: I have a Dvd stuck in the CD changer in disc 1.
on the front face of the dvd is a tiny hole which you slide in a rod or pin which releases the locking catch
SOURCE: I cannot get multi CD
This seems to be a failure of the micro controller of the unit as it fails to identify as well as display the functions.
You will need to check he connecting cord , check the connectors and the inner voltage to the circuits.
SOURCE: I have a bose wave
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Thanks.
SOURCE: My grandma has a Wave
First you'll need to take the cover off the system. Once inside you should be able to take the cover off the CD Tray and remove the CDs by hand.
