if they have wires or usb plug connections or if wireless might be a usb input device you plug in you will need to connect
your speakers to your computer then you will need to install them to your
computer if your computer came with
a motherboard disc the sound drivers could be on it click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question exclamation mark? ! or a red X
Right click to reinstall drivers click start control panel
sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settingsthere also click start control panel
sounds and audio devices select advanced there might be a tick in the mute box
untick it click start control panel
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar for any sound settings by right clicking on the speaker icon
then you are ready to position your speakers if you have
more than 2 you might need to select stereo
untick it click start control panel on the left select hardware and sound then
select manage audio devices then recording you should see a microphone right
click select enablewindows 7 click start control panel
icon in taskbar for any further volume control settings you will need to right
click on the volume iconsystem select
adjust volume hope this helps
the plugs usually red green and black/blue
the sound drivers might not have been installed for the sound card if your computer came with
game controllers you might see a yellow question mark? Right click to reinstall
drivers : click start control panel
icon in taskbar
probably no sound drivers: have been installed if your computer came with
icon in taskbar
untick it or select audio from the microphone drop down list make sure you
have the right one selected and in the volume box make sure the microphone box
has a tick in it or select the voice tab and make sure that you have the right
media selected also select volume make sure the box for microphone has a tick
in it click start control panel
untick it:
a motherboard disc the sound drivers could be on it: click start control panel
icon in taskbar if his does not fix the
problem click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this helps:
If you are having problems with you sound if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settingsthere also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in ithope this helps click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enablewindows 7 hope this helps
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar hope this helps
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar hope this helps you
