It istn!t getting startet. no photo can be done and no option to use the menu.
Please.
When an electronic device is start acting strange, a software update is the worst thing you can try to solve the problem.
Updates are only allowed if the system is working without an error.
If it is not working correct, you can't be sure it will load the update correct and you never know what happens when the update is started.
For every update there is a condition, the electronic needs to work perfect and the battery / power supply must be capable of delivering enough power during the whole update process.
I'm sure there will be no update for the Benq camera.
SOURCE: BenQ DC C850 blur focus
Try to Reset, if it doesnt work use your user manual for help, still if problem persists then it might be getting faulty and thus need to see more technical help.
SOURCE: blurry focus of benq c850
Possible that you gat a slow shutter speed. Or your camera might be getting faulty. When the shutter gets damaged then the blurry focus wont change unless its fixed. The four main causes of blurry photos are:
Unless its just technical or hardware you will need to visit a technician. or replace the Shutter.
SOURCE: I don't see photos on BenQ DC C1030 Eco
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
