After I wash my clothes in the machine can I put water in the dryer and then remove the soap from the clothes ???
You run the risk of destroying your dryer. Try rinsing your clothes
out in a sink or basin by hand, before putting them in dryer. Best
not to put dripping wet clothes in dryer.
Whether your dryer is electric or gas, DON'T PUT WATER IN THE DRYER!!! If you need to get more soap out of the laundry, run it through another cycle without soap.
SOURCE: order in clothes
Put a half a cup of vinegar into wash load, with soap. It removes the smells.
SOURCE: Water Draining off Automatically
Sounds like you have a siphoning problem. Click on the following link for instructions on how to determine if this is the case:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If this is not the problem, or if you need further advice, please post back and let me know. I hope this helps you.
SOURCE: suds residue left on clothes just washed
ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
SOURCE: Bosch washing machine not drawing water
you probably have the "burst free" hoses, this machine draws water too fast so the hoses think they burst, change the hoses to the original or get new ones that aren't burst free and this should solve your problem
SOURCE: My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
