Televison & Video Logo
Question about Samsung Televison & Video
I went to fast forward my tv show an the screen went black what causes it to do that
Went to fast forward a show I pressed fast forward an it froze i tried pressing play an it did nothing i flipped the channel an it went black
    Top Expert:
  • Samsung Master
  • 76,851 Answers
Unplug the TV from AC mains wall socket, and replug it back after 20 minutes or so. Check it after.
Electro help
Posted on Jul 27, 2014
5 Related Answers
Anonymous
  • 208 Answers
SOURCE: Sharp Aquos LC-46D64U Large black rectangle in lower half of screen
It sounds like the closed caption text mode has been turned on. Use you CC button on the remote and make sure the closed caption mode is in the off position.
Posted on Feb 26, 2008
Panso
  • 4 Answers
SOURCE: Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Posted on Jun 10, 2008
marionbagget
  • 718 Answers
SOURCE: TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Posted on Feb 24, 2009
Martin Murray
  • 1623 Answers
SOURCE: I was watching ch5 yesterday about 3pm when I
it might need a firmware upgrade, but you would have to contact grundig to see if there is one available
Posted on Mar 29, 2011
Anonymous
SOURCE: I was watching my TV last night and the screen
Generally in these cases that means it's a faulty cable or loose connection.
On LCD's if the screen dies or anything internally for that matter, the screen would stay black. Grey means a signal is coming through, but it's being able to receive it.
Solution:
Check your cables for any loose connections or try alternate cables going to your tv set.
Hope that helps. If you need anymore help let me know :)
Regards,
iMatt
Posted on Apr 06, 2011
Testimonial: "Thanks very much for your solution. I thought the plugs would have been ok because of the picture still coming through the DVD but I'll check them ton"
8helpful
My Nintendo 64 when I was in the middle of a game it froze and the screen went all black and then it went to the tv screen saying no signal then.
Well one time I had this problem with my Nintendo 64 console when I was in the middle of playing perfect dark the screen had froze went black and then it went to saying no signal on the tv screen. The console did not over heat to cause this problem. I thought that it had died on me but I had tried a new expansion pack and it was fine after that. SOmetimes the expansion packs can blank out in the middle of a game play they can die without a warning then. Or it can say expansion pack needed or it will give the white flash that it is turning on but nothing happens after that then.
I can't seem to be able to fast forward any more than twice speed. I know there is some way I can program it that it allows me to be able to do that but I can't seem to find in the manual where I...
Hi Henry,
  1. Usually DVD players DVD players come along with remote controls which have fast forward buttons which have the icon as ">>" .
  2. All you need to do , is press the button as per your requirement of fast forwarding.
  3. If you press the one, you would get a message as x2 on the TV screen and if you again press it , it would display x3 and if you press the button again it would show x4 , that is the maximum speed you can have usually for fast forwarding.
  4. So the solution is to keep pressing the button multiple times to change the fast forward speed.
Hopet his helps ...Your feedback would be appreciated.
Forward fasts on its own
you may want to try fast forwarding at 2x (that is, press the FF key twice), although the speed will be faster, it may actually stop for you, when you press play, rather than going to the end.
14helpful
2answers
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Playback
when I plug in the RPU DC cord from my camera to the input on my tv I get nothing. Is my input jack bad or what. Also, if I tried the s video jack from the camera to the tv, would that work??? I don't know what the AV out jack is for I don't have a cord for that
My Sandisk e260
press and hold the menu/power button until the player shuts off then wait for 10 seconds then turn the player on. This is usually cause by bad files in the device.
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Player won't play
Is it still under warranty? I would return to store for new unit, possibly a better one, I have had problems with protron equipment.
Marvin
Marvin
