Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
How dissemble 8804 belt replacment ? - Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
  • Bissell Master
  • 18,429 Answers
HERE VIDEO
Posted on Jul 27, 2014
Model 8804 t
Hello Jack. Not having the machine spray when you're ready to use it is frustrating and I'm sorry you're experiencing difficulty.
Here's a quick link to the our complete troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1052&cid=ccsocial
Jun 29, 2013 | Bissell Vacuums
How to change belt
this video will give and show you all the infomation you need to change the belt and clutch,
Nov 15, 2012 | Dyson DCO7 Upright Vacuum
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Powersteamer 1697, 8804 series, Smartmix will not despense cleaning solution
there is usually a button or release lever by the handle that u sqeeze to release salution
Jan 22, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I have an Easy-Flo central vac unit. The handle on the electric hose has a switch on the handle. With the switch on ''O'' in the center, it's off. On the left, is the ''I'' position. The vacuum runs but...
You can't get that apart. I repair the switches on these hoses a lot. The only way to fix it is to just get a new switch and replace it. You can get a replacement switch here:
Switch Replacement
Nov 18, 2009 | Vacuums
Howdo I replace dyson belt??
Replacing the belt on the DC-17 is not complicated at all. Once I understood how, the process took about 5 minutes. My best suggestion is to call Dyson and they will quickly and cheerfully walk you through it without making you feel stupid. Here is what they told me: 1. Remove the bottom plate that covers the beater bar, using a flat head screwdriver; pull the beater bar out so that it is only attached by the belt. 2. Use the flat head screwdriver to wedge the belt off the beater bar. It takes a little bit of wiggling, but it is not difficult. 3. Once the belt is free of the beater bar, use the screwdriver to unhook it from the gear that is attached to the motor inside. 4. With the new belt, repeat the steps in reverse, hooking the new belt onto the motor gear, over the beater bar, etc.
Apr 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
71 people viewed this question
Top Bissell Vacuums Experts
Marvin
Marvin
Mike
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
