Question about Hisense TA42P40M 42 in. Plasma Television
What to do when tv says run channel auto scan
    Top Expert:
  • Hisense Master
  • 76,455 Answers
The main system control memory IC is faulty. Replace it. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Jul 27, 2014
I have an Element ELEFT502 50 HD Digital tv. I am trying to connect my cable line to the TV but cannot get the past the auto scan screen
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
Feb 26, 2015 | Element Televison & Video
How do I run a channel auto scan on a Coby TV?
It will be in the setup menu. I believe with the Coby there is an initial setup screen which will guide you through.
Jan 18, 2015 | Coby Televison & Video
How do I run channel auto scan on Calypso TV
try going to settings ,menu then hit present or auto scan
Oct 26, 2014 | Calypso 26"" LCD Hd TV
Keeps telling me to run an auto channel scan
Check and replace its main system control memory IC. It is faulty. It does not hold the data. Gopakumar Gopalan Google
Feb 26, 2014 | Orion 24RTC 24 in. TV
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
Sep 25, 2011 | Dynex Televison & Video
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
Hisense TA42P40M 42 in. Plasma Television Logo
220 people viewed this question
Top Hisense Televison & Video Experts
David Tickner
Marvin
Marvin
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
