Wiring
SOURCE: I want to know electrical diagram toyota corolla 1995 1.6 4AFE
all the wiring diagrams can be found here for free.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528006f4db
hope you get it solved.
Ps dont forget to rate the solution. Thanks
SOURCE: 1994 toyota 22re 4x4 pickup fuel injector wiring diagram
the color of the plastic plug does not matter... You will have two injector plugs with white/red and yellow wires - those two go to cyl#'s 1 and 3.
the other two plugs will have white and blur wires.. those two plugs go to injectors # 2 and 4.
SOURCE: i need a wiring diagram for fog lights oem to my toyota
The link below is a Typical fog lamp / driving lamp hookup. Keep in mind that in most states, for these lamps to be 'legal' (and thus pass inspection), you must wire them such that:
1. You can cut them off (in other words, there must be a switch installed to turn them off)
and
2. They may only be operated with the low beams. (therefore, you must power your on/off switch from the low beam circuit)
http://www.accessconnect.com/fog_driving_lights_wiring.htm
Hi Christy Larina, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? You posted your message in the Antenna forum, asked for Toyota wiring diagram, but gave no model, type, or even what the device is. More info, and we'll try to help.
