Question about Cam Spray 4000BT 16HP Briggs 4000psi 4GPM Cold Gas Trailer Pressure Washer
I have a 16hp pressure washer Briggs how do I adjust the pressure?
Posted by Aline Fruge on
russlakeside
  • 37 Answers
There will be a an adjustment on the loafer valve on the pump itself. You may find it under a protective cap located on the pump.
Posted on Sep 06, 2014
Richard Warren
    Genius:
  • Cam Spray Master
  • 2,548 Answers
They are set at the factory if its dropped in pressure it couldhave popped an O . Ring. Check out.
Posted on Jul 27, 2014
Adjusting high and low water pressure
Clyde, Trouble shooting pressure washer links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pressure Washer FAQ Low or No Flow Briggs Stratton
DIY Pressure Washer Repair Help Troubleshooting Sears PartsDirect
Troubleshooting Your Pressure Washer
Common Pressure Washer Repair Problems Pressure Cleaned
Jun 27, 2016 | Craftsman 2500 PSI Briggs & Stratton...
HOW TO ADJUST VALVES ON 16HP TWIN 2
I recommend taking it to your local Briggs and Stratton dealer or authorised repair centre.
Or you can buy a manual from Briggs and Stratton for your make and model which will give you photographs from which to work.
That's what I did to service my B&S lawnmower.
Mar 15, 2015 | Briggs & Stratton Garden
Intek valve adjust
inlet .010" exhaust .012" cold
Jan 27, 2014 | Garden
Briggs and Stratton valve adjustment on 16hp vangard engine. model 280777
Find top dead center on piston.Set valves at 0004/0005.she should start easy.
Jan 27, 2014 | Parks Optical 13.5hp Briggs And Stratton...
2200 psi husky briggs and stratton pressure washer used 2 years never used soap dispenser trying now is not drawing soap no longer have manual to see how to connect adjust can you help?
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
Jan 16, 2010 | Briggs & Stratton Gas Pressure Washer...
No fire canged magnito & checked magnet
could be a low oil safety switch on the briggs & stratton gone bad. Try disconnecting it and fire it up.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jim_5aec98336eb33c13
Apr 26, 2009 | Briggs & Stratton Pressure Washer...
Cam Spray 4000BT 16HP Briggs 4000psi 4GPM Cold Gas Trailer Pressure Washer Logo
71 people viewed this question
Top Cam Spray Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Cam Spray Garden Expert? Answer questions, earn points and help others
