Question about LG LFD25860
How to remove freezer door on LG LFD25860TT? - LG LFD25860
LFX 28978 LG French door refrigirator too warm, frost in the back of freezer
call for service, could be a computer board, fan motor, or defrost system. cheaper in the long run to call for service
Apr 30, 2012 | LG LFD25860TT Titanium French Door...
Fan inside fridge not blowing
is the ice on the floor of the freezer?if so the freezer drain is blocked,ice is building up and the fan blade is jammed from the ice.when the machine gets cold ice forms on the evap coil in the freezer,when it goes into defrost the heater turns on and melts the ice and the water drains down a hole under the evap coil and the water goes down into a pan where it evaporates from the heat of the compressor and condenser coil but your drain is blocked and the water is leaking onto the floor of the freezer instead of going down the drain,i use a steemer to clear blocked drains but if you don't have a steemer you can use a hair dryer to melt out the ice,on your machine you can pull out the machine from the wall,remove the back bottom panel and unplug it first,then look at the right side,you'll see a plastic drain line with a wire tie around it,that's the drain line,you might have to cut the tie and then pull the drain line down and remove it,now go to the freezer,you have to remove the door and racks and then remove the back inside wall of the freezer,melt out all the ice that you see with the hair dryer,after you melt the ice go to the back and snake a long plastic tie like the one that's on the drain line or if you have a piece of 1/4 inch plastic water line or anything you can think of to snake through the hole where the drain line came off of,i would use plastic,if you use metal be careful not to damage anything,then pour hot water into the drain in the freezer,if it drains out the back hole you're done,if not keep hitting it with heat and if you have a turkey baster or anything that will push air down the hole to clear it and when you think it's clear pour more hot water into the hole until it drains.hope this helps and good luck with your machine.
Nov 15, 2011 | LG LFD25860TT Titanium French Door...
How do I remove the bottom freezer door from an lg refrigerator. Can't get it through the doorway?
After 9 days I imagine you have solved your problem but for those searching for an answer this is what we had to do. In the owners manual on page 15 it tells you to open the drawer fully, remove the lower basket (large one) by tilting the door. Now it states to press both hangers with your thumbs to lift it up. "Hangers" had us stumped. They are little notches, latches that you press in (depress) to release a locking effect, if I remember correctly each side has 2. This allows you to remove the white plastic rail covers. Next remove the 2 white screws; one on each rail near the bottom front. Then with both hands, hold both sides of the freezer door and pull up to separate it from the rails. We not only had to remove the freezer door but the 2 french doors as well. Hope this helped
Aug 18, 2011 | LG LFX25960 Bottom Freezer French Door...
The unit isnt cold anymore. The does not turn on. If i put it in test mode the fan will turn on. The fuse in the pcb board is still intact. What could the problem be?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 30, 2011 | LG LFD25860TT Titanium French Door...
The water supply stopped, I have replaced the filter.
ck the water valve but if ok adjust the temp as the water must be frozen .. hope this helps mm
Oct 21, 2010 | LG LFD25860TT Titanium French Door...
Ice maker is not working. Light goes on but no water fills the maker Model LFD25860TT
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | LG LFX25960ST Stainless Steel French Door...
Frozen Water in Pan behind freezer drawer.
yes you will have to remove the freezer door and go through the front of the unit. the door itself is the easy part to get off, it lifts off the rails, you may have to remove a screw a few inches back fromm the freezer door on both freezer rails(phillips head screw, ). empty the freezer pullout before trying to remove. after that the the pull out upper shelf comes and thenyou can remove the horizontal rails , the ice maker drops down and then the back wall can be removed
Mar 15, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
LG LFD25860 Logo
47 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
