SOURCE: Canon A75 Battery door
Never did it on an S1, but on other models it required removing the back face of the camera to access the battery doory hinge pin.
Examine your camera, and if this sounds feasible, remove all screws along the perimeter of the camera (keeping track of their sizes and where they came from, write it down with a crude drawing of their locations/sizes). Also look for screws in the battery compartment, and any visible screws behind flaps/doors. Once all perimeter screws are removed, you should be able to remove the back face of the camera by prying it open from the bottom. Once opened, the pin holding the battery door should be able to be slid out, enabling removal of the old door. Then in reverse slide the pin into the new door, and reassemble the camera and its screws.
SOURCE: My canon powershot a570 is not powering on despite changing the batteries. Any suggestions?
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
SOURCE: Canon PowerShot A630 power problem: NiMH batteries no longer work
I dont agree, I have tried several different batterie types and the batteries are draining almost instantly with the camera and they are not actually being drained. I think the camera itself is at the end of its life...as I have used rechargeable batteries for the last few years and now they wont even show as being charged on the camera. It stinks Im in your same spot now...no batteries are lasting even the brand new lithium ones...it has nothing to do with the battery "juice" but something with the canon supply power not recognizing/recieving the juice. Im not a canon expert, but I think the problem is more than the battery here Steve and im confused at the solution as well.
SOURCE: Canon Powershot SX10is All my action shots in
you should set it to a high shutter speed and f/stop also set your pictures to a RAW setting, if that made no sences let me know, and i'll say it abit more simple :)
