Question about KitchenAid Refrigerators
Ice cubes sticks together in freezer
Ice cubes sticking together in the ice bin
Ray Savellano
    Sergeant:
  • 324 Answers
Set the freezer temperature lower.
Posted on Jul 26, 2014
5 Related Answers
Anonymous
  • 111 Answers
SOURCE: ice cubes sticking together on ge modeltbx20tub
If the cubes appear to be shells, you have a restricted water supply to the refrigerator and will need to change the saddle valve where the 1/4" line connects to the house plumbing.
Posted on Dec 19, 2008
Anonymous
  • 149 Answers
SOURCE: In side by side whirlpool refrigerator freezer ice cubes stick
if they are hollow and stuck together then u are not getting enough water..check the supply.
Posted on Jun 11, 2009
Neciforo Llanto
  • 942 Answers
SOURCE: ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
Posted on Jul 08, 2009
Anonymous
  • 19 Answers
SOURCE: ice cubes melting and then sticking together
If you have dispenser to get ice or water, there is a cover to it that opens and closes as you ask for ice. If that mechanism is not working it stays open all the time and causes your ice to melt because cold air scapes. You should be able to replace that yourself. Sears sells that part. It is not very expensive. There is a cover over the dispenser pannel. It should right behind it
If you Agur that suppose to turn the ice to dispense, that could burn up too because the agur can not turn all chunk of ice
Posted on Aug 01, 2009
Anonymous
  • 351 Answers
SOURCE: ice from ice maker sticking together. Is the temp
to warm or maybe staying in deforest to long if you don't have a good amount food in the freezer it will warm up in deforest and make ice to lump
Posted on Sep 29, 2010
What causes ice maker malfunction?
you could try cleaning the ice bin first of all the accumulated ice cubes that are all sticking together at the discharge side of the bin. thanks.
Mar 04, 2016 | Kenmore Refrigerators
Ice sticks together
the ice cubes stick together because the water level in the tray is to high and the cubes can not be separated so turn the valve on the wall behind the unit closed some to lessen the amount of water in the tray
Apr 05, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Our GE Adora Refrigerator's ice maker isn't working properly
Perhaps your freezer isn't set cold enough - or your freezer door seal is not sealing correctly and the ice cubes are melting in the bin and sticking to one another and the spiral screw that delivers the ice.
Mar 14, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Blue Ice cube maker only make 4 instead of 12 cubes ?
It may just need a cleaning. Use approved cleaner for this modle and sanitize the bin after the cleaning. If it is making some ice, most likely there is not an issue with the charge.
Jan 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice maker shooting water along wall of freezer
Hi...
Regards
PCmania
Jul 08, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Jun 09, 2009 | Refrigerators
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice cubes sticking together on ge modeltbx20tub
Dec 18, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
Refrigerators Logo
268 people viewed this question
Top KitchenAid Refrigerators Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
