Brother MFC-230c Printer Logo
g
gail fleischaker Posted on Jul 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to clear 'prirnt unable 51' in 230c printer?
The error message came up just after I mistakenly hit 'color' and 'black' at very nearly the same time. Neither 'stop/exit' nor 'on/off' button have any effect. [resetting purge to 0000 did not work; pulling the power cord, waiting, and re-plugging the cord did not work]
rashid
Level 2:
Habit-Forming:
  • Expert 83 Answers
  • Posted on Jul 27, 2014
rashid
Expert
Level 2:
Habit-Forming:
Answers
83
Questions
0
Helped
32046
Points
157
The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Switching arm assembly not engaged correctly Ink cartridge/purge switch harness not connected correctly Purge cam switch broken Gear(s) on the maintenance unit broken Paper feed motor broken Main PCB defective.
best of luck
5 Related Answers
Anonymous
  • 32 Answers
  • Posted on Dec 09, 2007
SOURCE: Unable to print. Error message Machine Error4F
here read this:
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001887&Sympt=How+do+I+clear+the+message+Machine+Error+4F+from+the+display%3f&Model=89&ProductGroup=5&ProductID=MFC210C
Anonymous
  • 832 Answers
  • Posted on Mar 13, 2008
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Anonymous
  • 8 Answers
  • Posted on Sep 02, 2008
SOURCE: Brother MFC 5840CN "Unable to Clean" Message
I can send you the service manual that describes everything you need to know. What is your email address?
Samyfam
Samyfam
  • 379 Answers
  • Posted on Sep 07, 2009
SOURCE: unable to clean error message
This is very common on Brother MFCs - they self clean excessively and when they've done a set number of self-cleans, they refuse to print and give the error message you quote.
There is a work around - you can reset the self-clean counter - but this carries a small risk the waste ink from cleaning that is normally stored insde the machine in a tank/sponge MAY leak out. I've done the work around on my Brother MFC and, so far, no leakage so if I were you I'd take a punt.
Just Google "brother mfc unable to clean" and somewhere in the results will be how to reset the counter - it's all done from the keyboard so no tools required.
Anonymous
  • Posted on Sep 14, 2012
SOURCE: Unable to Clean 5A
The machine does not work due to a paper jam or some sensor problem.
Clear the paper jam, try to clean the sensor on the top of the printhead.
Unable to print
HI Jdingla,
Hi, I'm Zen and I'd be glad to assist you today.
If you click the link below, you can access a step-by-step guide on clearing such an error message rather than me typing it out for you.
How do clear the message Unable to or Unable Brother Still having Problem Then follow Us For
Brother Printer Support
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
1helpful
Problem in hp cp 2025 color laser printer that printer is giving error message "used black cartridge is in use error
This error typically indicates that the cartridge was moved (e.g. previously installed) from another printer to your printer. The error should not affect your ability to print. If you want to clear the error, replace the affected cartridge with a genuine HP replacement.
63helpful
3answers
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
Receiving a "Insert color cartridge" error message
You hit it! Go out and buy a new cartridge. Most likely you got a bad one.
2answers
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
1helpful
Supply Memory Error
It sounds like you are having two diffrent problems. I don't think they are associated with each other.
First, the memory supply error. The cartridges on this machine have a chip. The chip could very well be faulty causing this supply error message. Change the black cartridge and see if the message clears. if it dosen't then the antena that reads that chip needs to be replaced. I suspect the cartridge is the problem.
Second, the paper jams. This can be caused by a worn p/u roller as you mentioned. Sounds like the jam happens first then the error, based on your description.
The black thing you refer to on the door is called the "transfer belt assembly".
Ink cartridge?
Remove the color cartridge and power on the printer again, if that clears the error, replace it with a new one. Do the same with the black cartridge.
3helpful
here read this:
Norman Weimar
Norman Weimar
k24674
