Question about Integra Audio Players & Recorders
Integra 8.* fuse
I have an Integra 8.2 AVR that won't turn on. Suspect an internal fuse- how do I access and replace?
5 Related Answers
Anonymous
  • 104 Answers
SOURCE: 1996 acura integra idle surging?
Check this out, http://www.hondahookup.com/forums/showthread.php?t=147179
Step by step guide to diagnosing idle issues on your honda.
Posted on Oct 25, 2008
Curt Downs
  • 1779 Answers
SOURCE: acura integra engine torque specs
56 ft lbs torque main bearings, NON v-tech engine.
Posted on Jan 15, 2009
roniecon
Ronny Bennett Sr.
  • 6927 Answers
SOURCE: overheating 1992 acra integra
The coolant temp sensor tells the computer tempurature of engine at all times.It tells the coolant fans to come on,and also very important,when to cut off.If the fans don`t go off by them selfs,then temp is not going down.Now this is if the ac is off,cooling fans come on any time ac is turned on,so check for fans coming on and off with ac off.A bad coolant sensor would cause the fans not ot come on,but not to cut off nessasaralyCoolant systems must be bled of air trapped in systemfor the engine to be cooled .If air is in the system,the coolant won`t flow correctly.
Posted on Aug 07, 2009
Anonymous
  • 33 Answers
SOURCE: I have an integra dtr 7.7 receiver which when
obviously a short somewhere in the system....
you know what i would do?
pray to god you are still under warranty! XD
its a beautiful machine....
Posted on Jan 08, 2010
YellowNo5
Jeremy
  • 268 Answers
SOURCE: acura integra rs no spark no fuel pressure
Could be the main relay. It's behind the dash up above your gas pedal. Look for a gray and brownish box with one large plug in it. Should be easy to find since you don't have cruise control. It will be secured with one 10mm. You can bring it into reach with it still plugged in. Try starting it while tapping on the little plastic box. If it starts, pry off the cover with a flat head screwdriver and re-solder the broken connections. The break in the solder will be on the side with the sharp little things. It will be smaller than a hair. To find it you will need to wiggle it. Have plenty of light. Just hold the soldering tool on the broken one until the solder puddles around it and you're fixed.
Posted on Apr 29, 2010
My 92 Acura Integra is not starting could it be my transmission fluid level
Search Results
    "No start" Due to Failed Fuel Pump Relay : Acura Integra ...
    repairpal.com > Problems > Acura > Integra
    where is the fuel system relay located at?I have replaced the distributer 2 times and also the... 1992 Acura Integra. fuel pump???? The car does not start unless I ...
    92 Integra wont start! Very weirdo problemo... - Honda-Tech
    honda-tech.com/acura-integra.../92-integra-wont-start-very-weirdo-probl...
    Jun 13, 2012 - Re: 92 Integra wont start! Very weirdo problemo ..... 91 Integra LS Defroster/Water Leaking, Bigmo5328, Acura Integra, 8, 01-30-2014 12:14 PM.
    92 DA9 WILL NOT START!!! - Team Integra Forums - Team Integra
    www.team-integra.net > ... > Generation Specific > Generation Two
    Apr 5, 2010 - 11 posts - ‎9 authors
    I just bought a 92 integra with the B18A1. The guy I ... Team-Integra.net is the premierAcura Integra Forum on the internet. ... But it still won't start and I don't know what is up. .... Engine will not rotate when attempting to start 98 gsr cranks but won't start. - Team Integra Forums ...
    Feb 9, 2012
    1992 Acura Integra NO SPARK! - Team Integra Forums ...
    Feb 5, 2012
    92 integra wont start after driving - Team Integra ...
    Oct 17, 2010
    Car wont start! has fuel but lil spark..? - Team Integra ...
    Dec 1, 2008
    More results from www.team-integra.net
    My '92 Integra cranks but does not s
Jan 21, 2016 | Acura Cars & Trucks
1992 acura integra wont stay running
You need a scan tool hooked up and the fault codes read, suspect you have a crankshaft position sensor or igniter module issue going on here. Keep in mind that is just a guess so don't assume this is the problem get the testing done..
Jun 27, 2017 | 1992 Acura Integra Hatchback
1990 acura integra ls fuse box diagram
On this website you find fuse box diagram and description for Acura Integra (1990)
Acura Integra 1990 wiring diagrams fuse panel CARKNOWLEDGE
Dec 12, 2010 | 1990 Acura Integra Hatchback
Where is the A/C compressor RELAY located on my 1995 Acura integra LS ?
The fuses in an Acura Integra are located under the dashboard on the driver's side. The under hood relay panel, which is the one that controls the air conditioning, is found on the right of the engine compartment next to the battery. Replace it with only another 10-amp fuse to avoid damaging the electrical system.
Nov 28, 2010 | 1995 Acura Integra Coupe
1991 acura integra fuse box diagram
On this website, you find fuse box diagram and description for Acura Integra (1991 - 1993)
Acura Integra 1991 1993 wiring diagrams fuse block
Sep 29, 2010 | Acura Integra Cars & Trucks
Car when left alone for several hours will start but wont run, suspect relay or fuel pump, dont hear fuel pump kick on, which to try first, relay or pump? 1995 integra ls
When it won't start, try reaching up there and tapping the relay. It might take the help of a friend to turn the key over while you're trying to tap the relay. Or loosen the nut holding it and bring it down into reach. Anyway, if you tap it while your turning the motor over and the car actually starts, that's your problem. It happens more on hot days. You can replace it or take the cover off of it and look CLOSELY while wiggling the things. You may notice a broken solder joint on the bottom (where all the **** things are). The loose connections will be smaller than a hair. You can actually melt the solder with a soldering iron and it will fix it.
Apr 05, 2010 | 1995 Acura Integra Coupe
I need a wiring diagram for a 1994 accura integra
Visit the autozone.com website and register the car's information. It's free and you will have access to an online repair manual for the car. The wiring diagrams can be found there. ( I checked). Hope this helped and best wishes.
Sep 11, 2009 | 1994 Acura Integra
Honda Integra Headlights
you can use acura integra lights for your honda integra no mater which side is the wheel.
May 17, 2009 | 1992 Acura Integra Hatchback
49 people viewed this question
Top Integra Audio Players & Recorders Experts
Bill DiBrino
Level 1 Expert
Naheed Mir
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
