All the lights work but the machine will not work through its cycles.
SOURCE: aeg electrolux lavamat 74820 e91 fault
Hope this helps .
Shane
Testimonial: "thanks we need a repairman to do this thanks anyway"
SOURCE: My machine shows all dial
Hi, the error E91 means No communication between circuit boards ( Communication error between UI board and control board. Check wiring )
Possibly a duff connection on one of the board connectors. Power off, drag machine out onto the floor, remove covers, disconnect circuit board connectors and clean with toothbrush. May help to tighten them with a pair of pliers. Clean off any corrosion or crud, refit and test. Closely inspect the entire wiring loom and circuit boards, looking particularily closely at areas where the wiring touches the machine frame. Your'e looking for any signs of wear or fraying which would allow the bare wire to contact the frame. Check all wires and connectors generally for internal breakages - caused by movement of the wiring loom attached to the drum. Over a long period of time the wire strands inside the insulator break through metal fatigue. Although the outside of the wire appears ok the internal is open circuit. Pull on each individual wire - if they're ok internally, they shouldnt stretch.
SOURCE: Hi, I have and Electrolux
(pre-typed to save time- common problem!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
SOURCE: Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.
Hello - Typically error code E91 on Frigidaire washer indicates a communication error with the user interface to main control board. A certified technician will need to check the wiring between both parts. Either part could be defective or unit may possibly have faulty wiring. Depending on the diagnostic either or will need replacing.
