Swan SI5042 Steam Generator Iron The standby icon keeps flashing. The iron is not heating up and no steam is being generated. HELP!!!
SOURCE: I have a Swan S15040 steam generator iron, the
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
SOURCE: no steam from iron
check the dial is in steam position or maybe you may have build up in the line for the steam
SOURCE: Swan SI5042 2300 Watt Steam Generator I have lost
I believe this is the instruction manual - follow the link
http://www.swan-brand.co.uk/media/swan/ib/SI5040N.pdf
