Solution To repairdamage tothe firmware, the solutioncan be foundon googleseachengines.Example;Fixtranscendflashdrive,Fix sandiskflashdrive,FixPQIflashdrive,etc.
Check the camers's flash setting, make sure the flash has not been turned off. Also check the batteries, make sure they are fully charged, a low charged battery will not charge up the flash capacitors.
flash bulb could be burnt out...if it doesn't fire when when you push test, that's my guess as to the problem. Another possibility (although unlikely) is a loose connection in the flash.
Panasonic knows about this and can fix it. It involves replacing a circuit board. I sent them my camera (Elk Grove Village, IL repair facility) at the beginning of Dec with a letter giving six web sites reporting the problem and asking them to fix it free of charge. I don't think the camera was on warranty, but I received it back, fixed, and with no charge, in about a week. Panasonic really came through on this and there is clearly no fix other than this one... except to stop trying to take flash pictures.
there is no chance you can fix it.. you need prof service to fix it. internal flash circuitry malfunction is present. try shooting in program mode or manual setting ( not using flash).
My flash went out twice on my FD-95. The first time it was fixed under warranty and it was the bulb. This time I haven't fixed since I have my 707 now. It still works with the external flash like yours did before you dropped it.
If possible I would try and buy another external flash since your time is short. When I had my camera fixed under warranty it was just about to run out and they, the camera shop, told me I should get it fixed now instead of out of warranty because the cost could be hundreds just in labor alone.
Good luck.
