Question about Apple iPod nano
Blank and wont charge
My apple ipod nano is blank and wont recharge....
Posted by Jap737703 on
  • Mitch H Nov 26, 2007
    I have tried to charge my ipod and it wont the screen will come on and it will show the ipod apple but it will shut off again then it will sometimes come on and show that apple and says "Do not disconnect" and then shuts off again. At Times it will charge but no further than the red bar and then it will die and start all over. Wut can I do?
  • lisaohdee Aug 08, 2008
    My iPod ran out of power and the screen says 'No battery power remains. Please connect iPod to power.'. I have plugged my iPod into the computer but it won't recharge. PLEASE HELP ME!
Mitch
  • 752 Answers
Try the "Five R's" as found on Apples website. If still no go, then it's probably time for a new battery or a new Ipod.
Posted on Nov 08, 2007
  • Mitch
    Mitch Nov 27, 2007
    How is my answer "inapprpriate"?
After charging and unplugging from the USB port of my computer, the iPod screen goes blank and won't come back on. I have tried resetting, but no luck. Just in case it matters, I had not used it for quite...
Have you got a normal wall charger is so it is smarter to use that, becuase when you charge the nano or any ipod for that matter, it slowly makes the battery life shorter so i suggest start charging from the wall charger, but it might be too late but give it a go if you have one hope this helped
Dec 12, 2009 | Apple iPod nano
I plugged in my i pod and came back a hour later and the screen was black and was frozen and none of the buttons would work
you will need to reset your ipod this will not delete songs. 1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Oct 21, 2009 | Apple iPod nano MP3 Player
IPod nano wont recharge
I would suspect that the battery is no longer good, these must be replaced by Apple contact their websit for instructions on how to do this.
Mar 23, 2009 | Apple iPod nano
Ipod nano is dead
leave it on until the battery runs down.turn off and plug in to charge,Allow it to fully recharge.Turn on and it should have reset itsself.
Feb 11, 2009 | Apple iPod nano
Change language to english
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
-Logan
Dec 22, 2008 | Apple iPod nano
Won't start.
Press and hold the center button whle holding down on the menu button. This should reboot you IPod.
Jul 12, 2008 | Apple iPod nano 3rd Generation
Ipod not turning on or charing with computer
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If that is not able to fix your problem, contact apple or your dealer for more assistance or repairs.
If you need more assistance let me know. Good luck.
Jan 31, 2008 | Apple iPod nano
Blank screen on my ipod nano
my ipod is not started so what should i do ?
Nov 30, 2007 | Apple iPod nano
Nano does not work-blank
sounds like it needs to be recharged. plug it into the wall charger or your computer and do not disconnect until it tells you that the charge is complete... this takes time and disconnect it from the computer by dismounting it before disconnecting so not to cause problems
Jul 06, 2007 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
